Question about Ricoh Aficio AP600N Laser Printer
Reset maintenence kit without replacing it - Ricoh Aficio AP600N Laser Printer
2 Suggested Answers
SOURCE: replacement of the maintenance kit
I need more info or service program for reset sistem infomation (replace maintenance kit) on front panel,
Posted on May 14, 2010
Install maintenance kit
The Maintenance kit is a supply you can order and replace without a technician. Look for a door on the right side of the machine toward the middle. Open it and remove a light orange assembly. This is the Maintenance Kit and is what needs replaced.
113R00736 Maintenance Kit, Standard
604K53810 Maintenance Kit, Extended
Apr 24, 2013 | Xerox Phaser 8860MFP/D - Multifunction -...
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
configuration page or a supplies-status page
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Mar 24, 2010 | HP LaserJet 4345mfp Printer
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
8560 DN Replace Maintenance Kit
the maintenance kit keeps your melted crayons from sticking to the roller. You know the smell... and no you need a new one.
Sep 15, 2009 | Xerox Phaser 8500/DN Printer
80 scheduled maintenance
This issue is just like changing your oil or the timing belt on your car. If you don't fix it correctly it leads to other problems. So, be warned. :+)
Here's what the Lexmark KB says:
On the Lexmark T520/522 series printers, we recommend that the maintenance kit be replaced after every 250,000 pages. If possible, an authorized service technician should replace the maintenance kit parts on these printers.
On the Lexmark T620/622 series printers, we recommend that the maintenance kit be replaced after every 300,000 pages. The maintenance kit parts for these printers are customer-installable, but some dismantling of the rear area of the printer is involved.
Note: The maintenance kit may need to be replaced more often if the customer is running heavy media (like card stock or labels) through the printer.
It is possible to clear the maintenance error message without replacing the kit. The printer will still operate, but some print quality problems may arise. However, this is not recommended as the message serves as a reminder that maintenance is due. If the printer is under warranty, the customer has to purchase the maintenance kit and have it replaced in order to keep the warranty active, although the on-site replacement itself may be covered under the warranty.
The parts that make up the maintenance kits are:
A fuser unit
A transfer roller
A charge roller
To find the part number of the maintenance kit needed for your printer, see Printers / Maintenance kits.
Clearing the maintenance message
To clear the message, you will need to go into the printer's configuration mode. Do the following:
  1. Press and hold the SELECT and the RETURN buttons as you power the printer on.
  2. Hold the buttons for six to eight seconds after turning on the power, then release them. (If you receive the maintenance message, press the Go or the Select button to continue past it.)
  3. Now, press the right Menu arrow until you see RESET MAINT CNT.
  4. Select this. You may need to press the Select button again. The printer display should briefly flash SAVED.
  5. Power the printer off and then back on in the normal way. The printer should now power up normally.
  6. If it does not and the error returns, repeat the above procedure.
Jun 11, 2009 | Lexmark T522 Laser Printer
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
Ricoh ap4510 - Maintenance Kit Issue
For the message to be cleared you should enter the service menu and reset the replaced elements
Jul 28, 2008 | Ricoh Aficio AP4510 Laser Printer
Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Jan 15, 2008 | Xerox Phaser 8500/DN Printer
Ricoh Aficio AP600N Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
