Question about Samsung SGH-F480 TOCCO Ice Silver
Touch setting but there is no calibrate settings in my phone
My touch screen is not working frequently. Give me the solution? How to restore my phone when touch screen is not working
Hello there,
If your touch screen is not working frequently, what you have to do is to calibrate the screen or check for the touch screen sensitivity. To calibrate the screen, go to the menu of the phone and select the settings, from the settings select the screen option, then you select calibrate screen and follow the rest of the instruction there on, or you select the touch screen sensitivity and increase it from there.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | Nokia 5250 Cell Phone
How do i callibrate the screen for my samsung i5510i galaxy android phone?
If you are asking about the touch calibration
Goto Settings (in the program menu) > Language & Keyboard > Touch Input
Here you can calibrate the touch settings.
If you are asking about Display Calibration
Goto Settings (in the program menu) > Display Settings. Here you can calibrate settings for Animation, Brightness, Screen Timeout etc
Jul 01, 2011 | Samsung Cell Phones
Everytime i touch the phone it responds somewhere else, this happened on my last phone but i can't trade this one in, aparently there is some software that can re-calibrate it as i cannot do any of the...
This problem might have come due to a wrong calibration of the touch screen.Your phone might be having calibration option.Go to phone settings > Calibrate.
It will ask to touch paricular points.You can either use your fingers or the stylus.Do it correctly and your problem must be solved.
Good Luck !!
Jun 01, 2011 | Samsung Jet S8000 Cell Phone
My touch screen needs calibration
Hey
its simple just go to Menu > Settings > Phone Settings > Calibration
you'l be asked to tap on screen until the calibration settings are done.
Thanks.
May 03, 2011 | Samsung Star GT-S5233 Cell Phone
Touch screen will only work in bottom left corner
jackrose52 Hi put the keypad on the phone and reset the calibration on the phone you need to go into the settings and the go to touch and you will dee the calibration . BUT TAKE THE BATTERY OUT AND THEN PUT It back in the phone. Now after the phone resets, I want you to go to the settings and the calibrate the touch screen . If all this doesn't work call the warranty center number 866-406-5154. Tell them you situation and that you need a replacement phone. Hope this inftomation help.
Nov 26, 2010 | LG VX9600 Cell Phone
Hi my phone sgh-d980 my touch screen is hard how can i solve
There are various reason the touch screen of you phone might be hard.
1)The calibration of your might be changed.You have to set it correctly.
2)The touch screen sensor might be damaged or loosen,you have re-hot the connection.
1)To calibrate the settings:
In the idle mode Tap the phone and go to menu and go to settings and go to phone settings and then go to Calibration.
Menu → Settings → Phone
settings → Calibration.
Follow the screen and tap the screen with stylus, and follow the screen and save the calibration setting.
2)Since you say you are able to work with touch screen,your phone touch screen is not totally damaged...You have to just rehot the screen.If you don't have hands on in it please take it to the nearest service centre.I will cost very less.Its like soldering process.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 02, 2010 | Samsung SGH-D980 Cell Phone
EnV Touch VX11000 Cell Phone: I am having problems with my touch screen. It work...
once again try to calibrate if that won't work then restore your setting factory setting but before resetting it to factory setting take backup of your data
May 07, 2010 | LG enV Touch VX11000 Cell Phone
Need to calibrate my phone
click on start,settings,screen or start,settings,power,adjust backlight,screen!
Mar 19, 2010 | HTC Touch Cell Phone (Unlocked) - Soft...
HOW DO I RESET MY TOUCH CALIBRATION SETTINGS?
  1. go to menu
  2. go to settings
  3. go to more
  4. and then select touch calibration
Feb 24, 2010 | LG Xenon GR500 Cell Phone
Lg dare Touch accuracy is not within the range
Go to the main menu, settings and tools; touch settings : and then select calibration and touch the six targets to calibrate touch accuracy
Sep 04, 2009 | LG Dare VX9700 Cell Phone
Samsung SGH-F480 TOCCO Ice Silver Logo
29 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
