Question about Frigidaire FRS23R4A Side by Side Refrigerator
Fridge not blowing cold, Buzzing inside black ball "compressor"
My frigidare FRS26R4CWE is making a buzzing noise every 5 min from the inside the black ball on the fridge side i think its the compressor. Fridge and frezzer both not blowing cold air but fan is blowing and operating.... Do i need to replace the compressor?
    Problem Solver:
  • 14 Answers
The black ball you are reffering to is the compressor.It is trying to start..that is the buzzing.The start,and overload relay is probably bad..hopefully.Because if it isn't the compressor may be bad.Where your wires plug into the compressor...this is the relay.it should come off fairly easy.It is much cheaper to replace this part..than buying a new fridge.For instance i buy them for g.e. refrigerators all the time from an appliance repair shop at cost,and they are less than 4 dollars for me.So I assume they aren't too expensive retail.
Posted on May 18, 2009
Amana asd2624hes buzzing sounds
Sounds like the compressor trying to start and failing. Call out an engineer
May 19, 2012 | Amana Refrigerators
My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Aug 21, 2009 | Heating & Cooling
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
UNIT (ABOUT 4 YRS OLD) STOPPED COOLING FREEZER AND FRIDGE AND MAKES A BUZZING NOISE ABOUT EVERY 5 MINUTES.
buzzing noise is possibly the compressor tring to restart. It sounds as if the compressor is going into thermal overload. I would suggest the replacement of the compressor. Good Luck
Dave
Jul 24, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Frigidaire side by side fridge
Power to compressor must be off (about 5 minutes) before a restart should be tried. Some of these relays are thermal and must cool down before power is reapplied.
Sep 04, 2008 | Frigidaire FRS26R4A Side by Side...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Loud buzzing noise from compressor area and freezer not cold enough
I have a 1.5 year old GE refrigerator and freezer. This unit had not given me any problems until 2 days ago when I constantly heard a loud buzzing sound coming from the freezer. I called GE and Best Buy (bought it there) and asked to troubleshoot this over the phone. They suggested sending a technician over for $100 just for the visit + labor + parts which could add up to hundreds of dollars. So, I researched the web and blogs like this. The answer to my problem was simple. Something that I placed inside the freezer was blocking the air circulation vent. So, I turned off the whole refridgerator and I removed everything from my freezer. For good measure I dislodged some ice and frost that had developed over the vent. I carefully put back everything into the freezer, but this time being careful not to block the vent. I turned on the power and voila! No more buzzing sound!!! I hope this works for you too.
Oct 31, 2007 | Refrigerators
Frigidaire FRS23R4A Side by Side Refrigerator Logo
385 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
