Disable hp scanjet 8350 scanner sleep mode - Computers & Internet
  • 2072 Answers
SOURCE: Sleep Mode
Yes there is.But let me give you an explaination of somethign in the scanner.Once you turn the power save mode off, If the copier has sat for a while and saws WARMING UP, It is not the power save setting. The scan lamp also has to reach operating temperature for the machine to run. So even after Power Save is off, you may get an occcasional Please wait Warming up before a copy. There is no settings or changes for the scanner lamp warming. I throw that in so you don't suspect you did something wrong in changing settings.
Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  1. Press the [Enter] button. 'Machine Setup Tray 1 Size' will be displayed.
  2. Press the [Left] or [Right] arrow button until 'Power Save' is displayed, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button to select 'On' or 'Off' to enable or disable the Power Save mode.
  4. Press the [Enter] button to save the setting.
  5. If Off is selected, skip to step 9.
  6. If On is selected, press the [Left] or [Right] arrow button to select the required time interval.
  7. Press [Enter] to save the setting.
  8. Press the [Stop] button to return to the Standby mode.
Posted on Jan 11, 2008
  • 148 Answers
SOURCE: Disable sleep mode
To change the sleep mode: Press Menu Numbers 1, 8. From your key pad select the amount of time before the fax goes to sleep. 0 - 99 Press Set Press Stop/Exit You can find the user manual here for the future if you would like: http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000082/FAX4100_US_UG_0.pdf Hope that helps... Lbcoaster
Posted on Jun 27, 2008
  • 326 Answers
SOURCE: I want HP scanjet G3010 scanner software for windows 2003 OS
http://www.dll-provider.com/search/HP%20SCANJET%20G3010%20drivers%20server%202003.html?aff.id=1950&aff.subid=3
theres the driver but not sure about the utilities, try the driver and let me know how you get on
Posted on Feb 17, 2009
iwlsolve
  • 62 Answers
SOURCE: how to operate hp scanner
Hi and welcome to Fixya!
from below u can download manual
http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=391317&targetPage=http%3A%2F%2Fbizsupport2.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc00208907%2Fc00208907.pdf
Thanks for using FixYa!
Posted on Jul 18, 2009
potek18
  • 528 Answers
SOURCE: Computer will not wake up from sleep mode
- your comp is in hibernation mode
- go to control panel>>power management>>put to NEVER the sleep mode,hibernation,HDD,battery
- restart system
Posted on Mar 27, 2010
I having hp scanjet 8350 scanner+adf its not scanning and automatic document function also not working but when i disconnect the adf /tma cable the flatbed scanner start working perfectly but again when i...
Thank you for writing a complete question that we are able to understand. It's nice to see a well worded question on here for a change.
To answer your question, this sounds like either a driver or firmware problem with the scanner. You can download the latest driver for your scanner from the HP support site here (click here) and download the available firmware upgrade for your scanner as well from the same location.
I would check to make sure that you have the latest driver first, and install that first if you do not. Then I would install the firmware upgrade immediately after, since it seems to fix the error that you are experiencing:
"Scanner hangs and does not respond when scanning many pages from the flatbed."
Good luck and thanks again for the well worded question!
Feb 13, 2012 | HP Scanjet 8350 Flatbed Scanner
Can I make my HP5300C Scanjet operate on windows 7
Use windows7 Prof or Ultimate
Install XP-mode
Working in XP-mode
Install the sj664 HP software.
Though the USB device HP5300C can be found, the HP scanning software will not yet find the scanner. Because the scanner is shared between W7 and XP.
On the XP-mode taskbar disconnect the USB device HP5300C.
Then start HP Precisionscan and the scanner will function as before.
It is clear why HP does not advise this simple procedure.
Just because they did not present any clue triggered me to try it once more.
Jan Wondergem
Aug 22, 2010 | HP ScanJet 5300C Flatbed Scanner
Lost instalation CD without instalation what i do
Go to this site courtesy of HP:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1118281&lang=en&cc=us&prodTypeId=15179&prodSeriesId=1118290&taskId=135
Choose your operating system and download the software. Go ahead and install it and then your printer should start working again.
May 19, 2010 | HP Scanjet 8350 Flatbed Scanner
I can get it work, I install new drivers and adobe 9 but it's not working at all
adobe 9 version as some conflict with HP softwares, install adobe reader 7 or below and I am sure that will work,
HP is under process if finding a patch.
Sep 29, 2009 | HP Scanjet 8350 Flatbed Scanner
Free driver for HP ScanJet 6300C
ftp://ftp.hp.com/pub/softlib/software3/sj675/sj-22000-1/sj675en.exe
Download the file above > unplug your scanner > install the file above > reboot your computer (if needed) > login into your account > plug the scanner into your usb port > it should automatically detect your scanner > goto device manager > imaging device > right click HP Scan Jet .... > Click on Driver Tab > Click on Roll Back Driver > choose to run the driver on windows xp compatibility mode.
Or use the compatibility wizard to set scanjet pro to run on windows xp compatibility mode
Jun 21, 2009 | HP Scanjet 6300c Flatbed Scanner
HP Scanjet 8350 is only scaning in Black and White. It is supposed to be able to do color. Is there a setting that needs to be set?
Use the HP product assistant to adjust the settings. Look in your start menu>all programs> HP etc., or on your cd, or you can download the full feature software package from here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 17, 2009 | HP Scanjet 8350 Flatbed Scanner
Problem scanning multi page document
You do not say which software you are using but if you can afford PixEdit you can save to multipage tiff, Pdfs and so on. Also combine singlepage and mulitpage documents to one mulitpage and vice verca.
May 05, 2009 | HP Scanjet 8350 Flatbed Scanner
Hp scanjet 8300 error ROM CODE FAILURE DOWNLOAD FW
hp scanjet 8350 error ROM CODE FAILURE DOWNLOAD FW==== pl. help me
Nov 02, 2008 | Office Equipment & Supplies
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
