Question about Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
Minolta DI450 error code C-0920
Error code C-0920
  • Konica Minolta Master
  • 6,696 Answers
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 04, 2016
4 Suggested Answers
SOURCE: minolta dialta Di450 Error message C-143E
The Document Feeder has only 1 Malfunction code for any problem with it.
If opening and closing the front cover (while it is turned on) resets it and you can use the machine, dont worry about it.
The unit was prone to this false malfunction code.
If it returns very often, then get an engineer to have a look at it.
Posted on Jun 12, 2009
firecontrol7
  • 6696 Answers
SOURCE: Minolta Copier
The malfunction code is for a Polygon Motor malfunction. The motor that shoots the laser beam across the drum
Posted on Jul 25, 2009
love_but_tru
  • 3 Answers
SOURCE: minolta di450 error code c0201
i knw the solution
open the minolta box which is located on the front of the machine then u will see the small box on the left hand with a nut open the net and when u done u will see a small button press that button and then close the box and minolta box and press exit on the console the code will will remove
Posted on Mar 03, 2012
Error c13fa minolta dialta di450
Open close the front door if the code comes back replace the print head which houses the LASER and or the main board is bad. If you can find one very old machine build bye Minolta before merging with Konica now Konicaminolta
Oct 16, 2017 | Minolta Office Equipment & Supplies
Error Code c0045
Bop. Error Code c0045. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.officeimagingsystems.com/id169.html
Konica Minolta Di450 Error Codes
http://www.biz.konicaminolta.com/download/users-guide/c554e_c454e_c364e_c284e_c224e/en/contents/id16-_101076518.html
Aug 25, 2016 | Konica Minolta Minolta Di450 Di470 Di550...
Erace the c-of24 on di450
The code refers to a sensor that looks at the drum - it might be dirty or something else is going on check this Fixya-link: Minolta DI450 error code C0F24
Jan 17, 2015 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta di450 how i can solve this code c-0540
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 18, 2014 | Minolta Office Equipment & Supplies
In my machine when we switch on the machine the code c- 0920 appear
One of the trays has a lift problem, try clearing by touching the small wrench in the bottom left of the display (if the wrench isnt there open and close the front door) after touching wrench open and close front door, if that doesnt work one of the trays needs troubleshooting
May 01, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta di450 code: c1080 & c1082
di450 error code 1082 give me a solution
Dec 14, 2012 | Office Equipment & Supplies
Minolta di450 error code c0201
please sir, minolta copy di 450 ditected c 133b
Oct 22, 2011 | Konica Minolta DiALTA Di200 Copier
Minolta Copier
Jun 15, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta Di450 Error C1326
how to remove di 470 minolta error c1029
Dec 17, 2007 | Minolta DI-2010F Copier
Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902 Logo
83 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
