Our phillips 60pp9202 t.v. has a ''wave'' at bottom of screen and looks like picture is doubled, color seems to be a little off too, what do we do?
  • 39 Answers
Failure in color convergence circuitry. Common problem on these but usually a technician can make the repair on site. No "quick fix" I'm afraid.
Posted on May 18, 2009
LINES AT THE TOP AND BOTTOM OF PHILLIPS MODEL NO. 60PP9202/17F
no lamp for this model, it uses three picture tubes but the three D looking picture is a convergence circuit problem and is fixable.
Apr 04, 2012 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60PP9202/17F rear projection TV. its getting worn. The overall picture seems to have a slight haze and also seems to have lost the color contrast. yellows and whites are very similar and...
Thats most likely a CRT coolant issue where you will need to remove and replace the coolant in the CRTs ( picture Tunes) Thats a very common problem with Phillips rear projection. You can get the phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant for a 3 CRTs and the CD with instructions.
Jul 22, 2011 | Philips Televison & Video
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Philips 60PP9202 60" Rear Projection...
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
Double Blue Halo Effect and Blurry Blue Picture
thats a problem with the Blue CRTs coolant needing replacement. If you look directly into the blue and green CRTs while its playing you should notice a bunch of crud inside the lens indicating that the coolant needs replacement. You can get the coolant replacement kit for a phillips at the following link which includes the coolant and instructions
http://servicemanuals.vstore.ca/
Aug 05, 2009 | Philips 60P8341 60" Rear Projection...
We have a red green color seperation on screen. how do we correct this
You can get the phillips DPTV305 _ DPTV345 convergence repair kit at the following link . The repair kit contains the two ICs 12 resistors and the Deatailed instructions with pictures on CD. Just look under the Phillips repair kits category.
http://www.tvrepairworld.com/
Jul 12, 2009 | Philips 60PP9202 60" Rear Projection...
Double images-picture on tv is in unalligned red and green colors
You need the Phillips DPTV305 - DPTV345 Chassis convergence repair kit which is available at the following link. the kits contain the parts and detailed instructions on how to do the repair.Just click on the phillips repair kits page.
http://tvrepairkits.net/
Jun 23, 2009 | Philips 60PP9202 60" Rear Projection...
SPEED BUMP OR BOWING
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking. Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com for a kits.  Just make sure you replace both of the convergence chips and all of the convergence resistors.
Aug 25, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Aug 08, 2008 | Philips 60P8341 60" Rear Projection...
Phillips rear projection tv model #60pp9202/17f
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
