Question about Whirlpool Dryers
Whirlpool dryer its not drying the clothes. no heat
  • 3 Answers
If everything else works and only no heat it's probably the heating element. you can find instructions on the Internet on how to access the heating element. Test it with a multimeter on Ohms (resistance) setting. Touch the two probes of the multimeter to the two legs of the heating element. If the meter shows no continuity, element should be replaced. How that helps.
Posted on Dec 26, 2013
  • Coupon Thief
    Coupon Thief Dec 26, 2013
    Thank you! I took the part out by watching an online video and the heating element and housing was cracked and worn. Thank you so much! ;)
david04928
  • 102 Answers
SOURCE: whirlpool ultimate care II dryer: dry clothes sensor
Make sure that the vents are cleaned to include outside. Where it hook on to the dryer make sure that the housing is cleaned also. That should take care of the problem. Thankyou and if you need more help let us know.
Posted on Mar 16, 2009
Sea Breeze
  • 4654 Answers
SOURCE: dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
Posted on May 22, 2009
dniro592006
  • 121 Answers
SOURCE: Whirlpool Estate Dryer TGDS840JQ1 dryer runs but
when you say heat up is it at least getting warm...
you may have a igniter gone bad or your thermostat may have failed... your igniter is what has to ignite the gas to burn to make it hot. If its electric then your heating coil has failed and needs to be replaced
Posted on Jun 09, 2009
  • 1218 Answers
SOURCE: No heat to dry clothes. Dryer is 4.5 years old.
By far, on that machine the "thermal fuse" accounts for more than 50% of all heating problems.
Unplug machine and remove back cover. On the air chute in the middle back of the dryer you will see a small narrow bakelite device with 2 wires connected to it. It is held in with 1 screw.
You will need an ohm meter to test it, or remove it and have an
appliance parts house test it for you. If bad replace.
Whirlpool part #3392519.
The second common problem on that dryer is the heating element and can be checked with an ohm meter as well.
On rare occasions one side of the 230 volt supply is out.
The side running the motor is o.k. but the heater side has lost power.
Caution: your dealing with 230 volts here. remove plug receptacle cover and check with a volt meter for power.
Posted on Nov 03, 2009
  • 177 Answers
SOURCE: dryer not getting hot enough to dry clothes
First check the power coming in, you need 240 volts. 120 to neutral on both sides and 240 across both. If you are not comfortable with a VOM volt ohm meter call somebody who is.
Be aware when every you remove a panel you will be exposed to sharp surfaces. Unplug first and be careful!
Whirlpool dryers have a thermal fuse inside the back of the dryer, if this is open the dryer will not heat. You will need to check this with a meter it should be closed. A quick and dirty way to check it, remove it and wire it in a circuit with like a flashlite or radio. the flashlite or radio should work, this is a dirty way to check fuses if you dont have a meter.
While you have the dryer open, vacuum it out and clean the venting.
Please repost if you have more questions
Posted on Dec 30, 2009
Duet. Why does it run but no heat and doesn't dry clothes?
You most likely have a bad heating element.
Try this video
Jun 10, 2015 | Whirlpool Dryers
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
Dryer
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Jul 06, 2008 | Kenmore Dryers
Dryers Logo
174 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
