Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
HOTPOINT 3400 DOES NOT DRAIN totally
Where is most of the water draining from so i can see if there is a clogged drain or screen?what parts do i need to remove ?
    President:
  • 331 Answers
Hi Bob,
Yeah! I'm a Texan! Cool!
I'd almost bet that your dishwasher drain line is NOT clogged but simply installed incorrectly. If I'm right, some water from the sink will drain (siphon) back to your dishwasher making you believe that it's not draining properly. (BTW, I've had a thousand service calls run for just this problem, so I know of what I speak)
Look under your sink and take a gander at your dishwasher drain line... if it looks like this, it ain't right.
This allows sink/disposal water to siphon off to your DW. All you gotta do is loosen the clamp (in the pic), remove the drain line, pull as much slack as you can (without pulling to hard... like it'll break if you do that) and put a loop in it like this...
OK... after you get your loop, you'll need to tighten your hose clamp. As an extra measure of security (to keep the loop in place), secure the drain hose to your sinks water supply line.
There ya go! 15 minutes, no parts, no head-aches and you're done! Cool, huh? All you gotta do now is kick back and wait for the Cowboys pre-season! (BTW... if your drain is installed properly, write back and we'll go a little deeper into a diagnosis, OK?)
Posted on May 18, 2009
I have a hotpoint bwm129 1200 spin and I can't drain the water out of the washing machine. I have taken out the filter as it was clogged, cleaned up but the rest of the water has not come out of the d
You should be able to drain the water out by laying the drain hose down into a bowl. Does the pump function properly on final spin, that usually clears the water to allow the door to open. Parts are obtainable from Hotpoint Spares.co.uk.
Jan 29, 2015 | Hotpoint BWM12 Front Load Washer
Ice in bottom of freezer. What causes this?
Usually cause by a clogged drain in the back of the freezer. try to clean with hot water and make sure the water goes all the way downn to the drain pan. .
Note: all frost free refrigerator defrost a couple of time a-day; the water needs to drain into the drain-pan under the frig. check under the frig to see if the drain pan is totally dry, if dry, the drain is surely clogged.
good luck
Jul 22, 2014 | Refrigerators
Hotpoint Aqaurius WML520. No functions at all, motor does not spin, pump does not empty water out, none of the programs work.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 24, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Water doesnt drain and water nozzle doesnt spin...but it cycles
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Hotpoint 24 in. HDA3400G Built-in...
Hotpoint CSX22GR side by side refrigerator / freezer. Ice in bottom of freezer and water leaking on floor on freezer side. How do I find the problem??
The problem is the defrost drain is clogged, the drain is located on the lower part of the back panel and can be gotten to be removing the drawers and to clear drain push a wire hanger through it till small hole delvolopes then flush w/hot water till completly clear
Jul 25, 2011 | Hotpoint Refrigerators
My diswasher has alot of water in it after we run the dishers thru. May be a clog? How can i check if there is a clog?
Hi
Daniel
Jun 19, 2011 | Hotpoint Dishwashers
Water not draining from dishwasher modle number hotpoint DWF32P/29 how do i get to the hose to see if its blocked
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 08, 2011 | Dishwashers
Does not drain. Water stays in the bottom.
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Apr 13, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Premature drain on Hotpoint HDA 3400 dishwasher
hello my name is gilles the problem you have their is something stuck in your drain valve causing the valve to stay open remove the valve clean out reintall every thing should be fine thanks
Mar 15, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Hotpoint aquarius extra wma46
The first question you need to ask yourself is, "is the drain pump running?" If you can hear the drain pump running when it tries to drain, then more than likely you have a clogged drain pump, or drain line. Here's how you can determine which one: You can check the drain line by seeing if it collapses when the pump starts to run. If it does, then you know you have a clogged line somewhere BEFORE the pump. This usually means an article of clothing has gotten between the wash basket and outer tub and is stuck in the line. If the line is full of water and doesn't seem to be going anywhere, hook up a wet/dry shop vac to the drain hose in the rear of the machine to see if you can pull water from the tub, through lines, and through the pump. If you can't, you know you probably have a clogged pump, or drain line AFTER the pump. If the drain pump does not come on, you may have a pump failure. In either case, you need to drain the water from the tub. A wet/dry shop vac does a great job at pulling water from the tub, so you don't have to bail. Let me know if this helps.
Jul 22, 2007 | Hotpoint WMA46 Front Load Washer
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
667 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
