Question about Samson Technology Zoom H1 Handy Recorder
Zoom H1 won't connect via USB
Hello, I'm having trouble accessing the SD card-reading function on my new Zoom H1 (out of the box today). When I connect the H1 to a computer via USB (I've tried by Mac and PC) nothing much happens. The manual says I should connect the H1 when its power is OFF. I've tried that, and the computer neither detects the H1, nor does the H1 spring into life and display "USB card" or "USB audio" as the manual says it should. I've tried connecting when the H1 is on. The ONLY noticeable sign that anything is happening is that the battery icon disappears. So it would seem that the H1 can draw power via the USB cable. But otherwise nothing. The cable and the usb ports work ok with other devices. I'd much appreciate any ideas.
4 Suggested Answers
  • 5603 Answers
SOURCE: I just bought a Zoom
OK... first thing is to make sure the SD card is 2 Gb or less as larger won't work.
Many of the SD card has a protect switch that prevents writing to the card... it is a real tiny littl thing to move with your fingernail. You might need a magnifier to see it.
Posted on Apr 01, 2011
  • 5603 Answers
SOURCE: I am trying to connect
Your Windoows Vista MUST have Service Pack 1 installed. Check that SP1 is installed.
Posted on Jul 19, 2011
  • 367 Answers
SOURCE: I HAVE A ZOOM R24
So I assume when you say you downloaded the latest drivers, you are talking about the version 1.3.0 from this source: http://www.zoom.co.jp/downloads/r24/
Ok so to configure Apple Logic Pro to use this control surface follow these instructions:
CONTROL SURFACE SETUP
1. Select "Preferences" > "Control surfaces" > "Setup..." from the "Logic Pro" menu. This opens the "Setup" window.
2. Click on the top left "New" and select "Install" from the pull-down menu.
3. Select "Mackie Designs/Mackie Control/Logic Control" from the list in the "Install" window and click the "Add" button.
"Mackie Control" will be added to the setup window.
4. Click the "Mackie Control" icon. Then, from the top of the list at the left set "Out Port" and "Input" to "ZOOM R16_R24" using their pull down menus.
FUNCTION KEY SETUP
1. Select "Preferences" > "Control surface" > "Controller Assignments..." from the "Logic Pro" menu. This opens the "Controller Assignments" window.
2. From the "Zone" column select "Control Surface: Mackie Control." Change the functions as you like.
3. Controls F1~F5 correspond to the F1~F5 keys on the R24.
The above procedures are for Logic Pro 9. The names of the menus, for example, might be different in a different version of Logic.
Make sure you have run all the MAC OSX updates from your System Menu > Check for updates.
This device needs full USB power so don't run it off a USB hub unless its a powered one.
Posted on Sep 09, 2011
Zoom h1 handy recorder
Have you tested the Micro SD card? Check it with your computer and load an MP3 to it. Play the recording in the Zoom to check the Zoom
May 27, 2014 | Music
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
Download the H1 driver for windows & try different usb cable........
Mar 09, 2017 | Music
H4n zoom wont record says card protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 23, 2013 | Samson Technology Zoom H1 Recording Bundle...
My new Zoom H1 will not connect to computer through USB.
Hi did you get it sorted,got the same problem,dont want to have to send it back only got it today, saving for ages,can you help
Oct 28, 2012 | Samson Technology Zoom H1 Recording Bundle...
Zoom h4n won't connect as mic via USB
What I figured out - simple. Plug your usb cable all the way in. That's it. Did I guess it? ;)
Apr 12, 2012 | Zoom H4 Handy Recorder
I just bought a Zoom H1 and the SD card won't format. What should I do?
Apr 01, 2011 | Samson Technology Zoom H1 Recording Bundle...
Can't connect the h4 handy recorder to a mac
If you are using a Mac running Leopard (Sys 10.5), you need to upgrade the H4  firmware from Zoom website
http://www.zoom.co.jp/english/download/software/h4.php
You will need an external SD card reader.
Good Luck
Nov 18, 2008 | Zoom H4 Handy Recorder
Samson Technology Zoom H1 Handy Recorder Logo
144 people viewed this question
Top Samson Technology Music Experts
Michial Gueffroy
Chris Larocque
DROPNDEAL
DROPNDEAL
Are you a Samson Technology Music Expert? Answer questions, earn points and help others
