Question about Yard Machines Cultivator
Worm pin on yard machine cultivator broke, don't need the whole drive shaft, where can I get just the pin?
  • 376 Answers
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 click on Option 1, choose your brand (Yard Machines), and enter your model # then search for your part. If it is available there, you can order it form any MTD dealer or order it online.
Posted on May 18, 2009
Tru-test tiller parts
Is there a bushing on the front of the drive on a tru-test tiller
Apr 11, 2012 | Garden
Hi Yard Machines rear tiller looks like 216-430-000 but no numbers on mine. was running tilling fine when all of a sudden tines stopped spinning. When shifting to till feels like no positive engagement....
There is a SHEAR pin that could also be broken. It's there to protect the sprocket from breaking in the event of hitting a rock or something large while tilling. You will have to go to the MTD website who makes Yard Machines, to get the directions on changing the pin or the chain whatever the case may be.
Mar 06, 2011 | Yard Machines Tiller 208cc 18in Tilling...
I have a snow blower which will start up but it won't move forward in the snow nor will it push the snow. Not sure what is wrong. I can manually move the blade around that pushes the snow.
If you start the machine and the axles spin but the augers do not it is because the shear pins are broke. If you look closely you will see the the augers have shear bolts and nuts or shear pins. If you jam a piece of ice or a stick in the augers while they are spinning the bolts will shear so you do not damage the expensive augers or the worm drive gears. If the axle spins with the augers you may have torn up the front worm gear in the front of the auger intake. If you spin the small auger and the large auger moves but when you start and engage the auger nothing happens you will have to remove the under cover and inspect the drive belt pulleys for jammed or broken parts or more commonly broken drive belts.
Jan 28, 2011 | Mtd 22" Yard Machine Push Mower
My 6 hp yard machine tiller has a problem when you pull the rope. It has a hard **** or pull back when you pull on the rope. Is the engine out of timing. Thanks JD James It is approx. 4 years old...
sounds like the timing is off.
need to remove the pull cord cover and take the nut off on the shaft and take the cover off and see if the key on the shaft is broke and put a new one on.
when you hit something solid the key will shear.
Jan 26, 2011 | Mtd Products Yard Machines 158CC Tiller
Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Mar 24, 2010 | Mtd Products Yard Machines 158CC Tiller
I need a worm wheel for a Honda minitiller FG100.
You can buy parts for this from www.petessmallengine.com
I had to replace the tine shaft w/worm wheel assy. This is usually the weak point in the transmission. The worm is made out of brass.
Jan 03, 2010 | Honda 25cc 4-cycle Mini Tiller
I need to remove a bent blade on a yard machines 42 inch deck.
To remove the blades from a tiller, all you need to do is pull the pins out of the blades at the shaft and remove the offending blade. If it is an inner blade, it too will have a pin. The pins have a head on one end, pass through the shaft, and a locking pin through the other end.
Regards, --W/D--
Jul 20, 2009 | Mtd Products Yard Machines 158CC Tiller
Ariens snowblower auger wont turn
Just finished repairing my ariens, 6 years old with aluminum gear box. Same problem encountered. The problem turns out to be the BRONZE gear driven by the worm shaft. Shear bolts did not shear and bronze gear broke about 5-6 teeth. This is why you can move the auger a half turn or so, there are no gears in one area of the gear and as the gear turns to engage the worm drive it will stop. The fix: the cast iron replacement from ariens! About $200 including shipping, got mine from Jack's Small Engine (MD). Fairly easy repair if you are mechanically inclined. Buy yourself a set of roll pin extractors ($20 from Sears), new roll pins, new woodruff key for shaft. You will also probably have to press 2nd stage impeller from shaft with hydraulic press & heat (took mine to my local auto garage). What stinks is ariens seemed to have admitted the design problem with the aluminum gearbox, yet won't help with repair cost! Anyways, I learned a lot about my snowblower for future repair (belt replacement)!
Dec 21, 2008 | Garden
Yard Machines Cultivator Logo
181 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
