Question about Pioneer PureVision PDP-5040HD 50 in. Plasma HDTV
"Current Settings Do Not Allow Selection and Adjustment"
How do I get around this problem? I can't make many changes to my programming
  • 1 more comment
  • jgoodman917 May 18, 2009
    Correct. I am trying to enable use of the HDMI cable but under the Home menu and options, the HDMI settings choice does not allow me to enable it---I get the message "current settings do not allow selection and adjustment"--I need to find out how to change the "current settings"
  • Devon Sacco
    Devon Sacco May 11, 2010
    I went over the manual, it says nothing about HDMI. I believe it doesn't support the HDMI format. I'm sure it's the reason why you can't make any changes to it.
    From the diagrams, it doesn't seem to a HDMI port. How do you have it hooked up?
    I'm starting to thing I might have the wrong manual. The PDP-5040HD was printed in 2003. Maybe your TV is a newer version of that model.
    Is there any extra numbers or letters next to the model number?
  • Devon Sacco
    I have a copy of your manual. The PDP-5040HD right?
I've got a sym husky 125 when I change gear I have to push the gear lever down abit to change again is this normal ?
the lever should return to a central position so as to allow selection of the next gear
if you have to push it down a bit before next gear selection is possible it may need adjustment back to that central position
get a manual as to how to do that or take it to a service dealer and have them adjust it for you.
May 05, 2015 | Sym Motorcycles
Tip
Windows 7 Tip#4
Modify UAC
The User Account Control security feature was one of the most reviled additions to Windows Vista, with good reason -- its constant warning messages asking for permission to continue many operations drove users around the bend. UAC has been significantly improved in Windows 7 so that it's not as intrusive as in Vista, but you can still tweak it if you like.
Here's how to turn UAC on or off, and make it less or more intrusive than the default:
1. Go to the Control Panel --> User Accounts and Family Safety.
2. Click User Accounts, then click Change User Account Control settings.
3. From the screen that appears, use the slider to select the level of protection you want. Here are the four levels and what they mean:
Always notify me. Think of this as UAC Classic. It works like Vista's UAC: When you make changes to your system, when software is installed or when a program tries to make a change to your system, an annoying prompt appears.
Default -- Notify me only when programs try to make changes to my computer. This is, obviously, the default; make a change yourself and UAC leaves you alone. When a program makes a change, a prompt appears and your desktop goes dark, just like it does in Vista. Otherwise, UAC sits there silently.
Notify me only when programs try to make changes to my computer (do not dim my desktop). This setting is identical to the default setting, with one difference: It won't dim your desktop so that you only see the UAC prompt asking you to take action. This presents a slightly elevated security risk over the default setting, because theoretically a program could allow a malicious program to interfere with the UAC prompt.
Never notify me when: In this one, UAC is completely turned off. This is, of course, an insecure option and not recommended for most users.
After you make the selection, click OK. Depending on the selection you made, you may need to restart your system for it to take effect.
on Jan 04, 2010 | Computers & Internet
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
How do I fix a thermostat that appears to have lost its programming?
Have you changed the battery?
usually the battery compartment (and the model number) on located on back of thermostat
Look up manual on internet
Gene
Water Heater Timers Save Money
Nov 11, 2014 | Hardware & Accessories
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Oct 20, 2014 | Siemens optiPoint 500 Standard Corded...
How to unlock region code for SA-xh175?
Are you referring to the region cdd for the DVD player?
For that I only have one answer, because it can't be changed (more than once) on the player.
The only way to get around the region codes, is to rip a DVD to your computer and remove the region code. Then burn the DVD to a DVD R. There are programs around on the net, but I'm not sure it is legal in all countries.
Google for the programs.
A DVD player sometimes allows you to change the region code once. But it not even would allow you to switch back after you changed it once.
Jul 21, 2014 | Panasonic Audio Players & Recorders
How do I unlock the DVD region code?
Jul 16, 2014 | Panasonic Televison & Video
Curtis dvd unlock
The only way to get around the region codes, is to rip a DVD to your computer and remove the region code. Then burn the DVD to a DVD R. There are programs around on the net, but I'm not sure it is allowed in all countries.
Jul 16, 2014 | Televison & Video
Curtis region
Pioneer PureVision PDP-5040HD 50 in. Plasma HDTV Logo
480 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
