Question about Quasar VHQ400 VHS VCR
Toshiba vcr operates for a few seconds then shuts down
  • Quasar Master
  • 5,190 Answers
When a VCR encounters a problem with the drive mechanism the unit will shut itself off to prevent further damage. You should take the top cover off and look around at the mechanical section for damage. If you can't see anything, leaving the top off, insert a video and watch what happens to it. This will give you a clue to the problem.
Posted on Dec 27, 2013
Panasonic Ag-DV1000 mini DV deck shuts down after inserting tape
When there's a problem with the drive mechanism of a VCR it will shut down to prevent damage. All operations of a VCR are controlled by a computer chip. This is told what mode the mechanism is in by a Mode Switch. If this is faulty it can cause the machine to play up. Sometimes a spray of Video 40 on the mode switch can restore operation. However it will not correct the problem if the mechanism has any damage on it.
Feb 25, 2014 | Panasonic AG-DV1000 Mini DV VCR
Every time i try and rewind tapes they stop after a few seconds and the vcr shuts off
There could be a problem with the drive system such as a worn belt or other damage. VCR's have a mode switch which tells the electronics what position the mechanism is in. If the vcr can't perform correctly the mode switch tells the electronics to shut down. However mode switches can go wrong and give error readings to the electronics having the same effect. You need to check both the drive and mode switch.
Feb 17, 2011 | LG MG64 VHS VCR
Toshiba d-vr660 shuts off when video is inside
If the problem is the vcr section you load a tape and it shuts down, it probably is the idler assembly that is not transporting tape correctly. I recommend a vcr/tv tech to check the unit with an estimate.
Dec 29, 2010 | Toshiba DVR660 DVD Recorder/VCR
LG280W VCR safe mode
hold the power button down for a few seconds or press stop
Jul 23, 2010 | LG MG64 VHS VCR
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
My toshiba tv turns off on its own, sometimes it will stay on for a few hours, other times only after 5 minutes it will go of
Ok This may be due to having a heated CPU/MOTHERBOARD and can cause a fuse to shut down to stop further damage like when a computer detects problems. My solution would be to get an airated space and when it shuts down feel the back of the tv to feel for heat, open windows when turning on or blow a cool hairdryer into the back of it.
Feb 06, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Tape stuck in an Emerson Model EWV401 VCR
take it to someone who has experience in removing stuck VCR tapes or you will be paying a lot more for a new VCR. They won't charge you much....IF they even charge you.
Apr 04, 2008 | Televison & Video
Toshiba Satellite A35-S159 Shut down
If it does the same thing when it's plugged in, it might be time for a trip to the service center.
Mar 21, 2008 | Toshiba Satellite A35-S159 Notebook
Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
Aug 30, 2007 | Toshiba M655 VHS VCR
Quasar VHQ400 VHS VCR Logo
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
