Fault code e02 hoover wdyn 856dg washer/dryer
What does this mean
  • 27 Answers
SOURCE: Bosch Nexxt Washer Error Code E02
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
Posted on Jun 26, 2007
SOURCE: Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Posted on Aug 09, 2008
SOURCE: Bosch washer/dryer
I also have the same washer and same problem, and it is not due to clogged filters nor due to low pressure!
Any solutions so far?
I wish I had read these posts before buying it. :(
Posted on Nov 01, 2008
  • 155 Answers
SOURCE: My hoover washer dryer VHD is showing a fault E11
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Posted on Apr 10, 2010
  • 343 Answers
SOURCE: iw712 fisher and paykel washer has fault code 37 w...
37 is drain error..There could be electronic reasons, but the most common problem is that there is a clogged pump or something is jammed in the pump impeller... Empty the machine of water and lean back against the wall so you can get access to pump, which is clipped to the bottom of the drum..Try turning the fan and see if the pump is blocked'/jammed.....Disconnect the wires and rotate the pump motor anticlockwise...It will be prevented from turning by a small plastic latch. Unlatch and remove pump motor...Remove any detritus and refit pump motor....If the motor resistance is less than 33 ohms (230volt) or 7ohms (110volt)..the pump motor itself might be the cause of the fault code, and should be replaced......This is a very simple job for a tech...Good luck....Nomess
Posted on May 24, 2010
My may tag washer has codes F06 & E02 , what does this mean?
I beleive e02 is something to do with ur drain pump set up clogged or damaged water pump and hoses
Jun 15, 2015 | Maytag MHW6000XG Maxima High-Efficiency...
Hi what does e11 mean on my hoover dynamic 6+5 wdyns 654 d mean pls?
Code E11 indicates an open circuit between the heater and the control board. The code also can indicate damaged wiring between the sensor at the top of the drum and the control board. The wiring can be damaged by drum rotation.
Feb 09, 2015 | Hoover Washing Machines
Error code E07 on my Hoover WDYN 854 DB results in me not being able to open door after a wash cycle any ideas how to open door
Switch off and for Door lock fault or Motor fault .
Check both are ok and make sure nothing is jammed or restricting the operation as it is according to which main board is fitted to the machine.
Feb 02, 2015 | Hoover Washing Machines
I have an error code E07 on my Hoover WDYN 854dB which results in me not being able to open the door after a wash cycle any idea how to open the door
make sure its drained 1st even drop hose to ground level which will gravity drain then door should open, could be blocked filter.
Wot is e16 mean
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3450-hoover-optima-fault-codes-carbon-brush-motor.html
looking here i see that error 16
tells us that the heating element has gone bad and needs replaced
or the wiring is bad
could just be a loose plug on the htc/ temp regulator
you can check it but its pretty clear by the error
so look to hoover spares ebay etc espares etc for the cheepest if you feel like replacing it yourself
Dec 09, 2014 | Hoover DYN8163D8X White 600 mm Washer...
Washer will not run
f06 OR e02 error code means you have an interface communication error. the main control board isn't communicating with the front interface control board. if you pull the washer out and remove the 3 screws coming in from the back of the top panel. the top panel will pull straight back, up, and off. check all the wire connections between the two control board and make sure they are all secure. if everything looks good, then the interface control board may need to be replaced.
f01 e02 means that your motor control board is not reading the tachometer on your motor when it tries to turn the motor. it thinks that the motor is struggling. open the door and turn the basket to make sure it spins freely.
Sep 28, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
What do these 2 codes mean on my maytag washer , F06 and E02?
The error code E02 and F06 on a Maytag washer could mean that the hot water solenoid went out. It could also mean that that the hot water control is not working properly.
Sep 23, 2014 | Maytag Washing Machines
Hoover wdyn 9666pg-80 error code E11
I fixed ours! here is a video of how i did it, it shows where the wire snaps and what part the wire connects to:
May 11, 2012 | Hoover Washing Machines
Hi Have got a hoover optima about 18 months old. Has got an E02 message in the middle of a cycle because the water board have turned the water off without telling anyone. Can't open the door or get...
'E02' for your Hoover Optima states 'fill time-out' which is not surprising considering that the water board turned the water off!
I hope by now that the water is back on and so is your washer ;-0)
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 27, 2011 | Hoover Washing Machines
Hoover wash-dryer 110 soft wave It doesn't centrifugate. I would imagine that I have to clean the filter, but I cannot find the filter. Thank you beforehand for your help. Christina
hi christina,,,its dont centrifugate???????? hmmm! do you mean spin?
or it dose spin,,, but dont pump out? if its not spining there is a program fault,,,or motor fault,,,,if it dont pump out,,,thats a pump fault,, program fault or a blocked filter,,,the pump has its own motor,,,however if there is a program fault that could cause the pump to fale to pump as well???
my brain hurts now!
Aug 07, 2010 | Hoover AAA160 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
