Question about Clothing Accessories
What is a good brand for cycling leg warmers?
  • 519 Answers
Posted on Dec 27, 2016
    An expert who has written 3 tips or uploaded 2 video tips.
  • 54 Answers
The Assos company makes great cycling leg warmers that can be put before shorts and if pulled up high enough they won't slide down. They can be used for a very long time before needing to be substituted.
Posted on Dec 26, 2013
When you buy leg and arm warmers do you need to buy two or they come in pairs?
Arm and Leg warmers usually come in pairs so unless you want more than one pair you can just buy one set. If you are in a store, though, you might as well ask the shop assistant and make sure you will bring home a pair rather than a single one.
Dec 26, 2013 | Clothing Accessories
Can leg warmers be used as arm warmers too?
Yes. It is not what they are meant for and it will look a bit odd, but you definitely can do it if you like it.
If it helps, you can also make little holes for your thombs so that it will look a bit more like an arm warmer.
Facts about vikings
Viking Warrior Costume features a brown tunic with chainmail sleeves, an attached faux suede belt and faux fur around the forearms. Leg warmers are similarly covered in faux fur, and the helmet has two horns coming out the sides. Throw on the fur-trimmed cape and you're ready to set sail!Adult Viking Warrior Costume includes:
  • Tunic
  • Helmet
  • Cape
  • Leg warmers
Oct 29, 2013 | Viking Adult Viking Warrior Costume
What is the best fabric for leg warmers, I need one that will keep me warm
Get wool ones, but make sure that they are knitted very tightly so no air can penetrate through holes. Also I'd use fleece ones, I think fleece is the best to keep you warm in extreme weather
Jan 10, 2013 | Clothing Accessories
Where can I find fleece hand and leg warmers?
I found those on Ebay, they look good:
Brand new amana washing machine NTW4500XQ0 unbalaced spin cycle how do I open to check springs
hi ,,if its brand new it most likely you have not removed shipping materail..its a yellow ******** back bottom of unit..pull it towards you that should release the legs along with tub...if unsure check the install book that came with unit...good luck [pull yellow strap all the way out ]
Sep 07, 2011 | Amana NTW4500XQ Washer
My brand new amana washer shakes violently when spinning
try adjusting the feet on the bottom of the washer the floor may not be level to adjust the legs turn them with a wrench or if the lock nuts are not tight turn the legs clockwise as you look at the front of the machine till all four feet are sung on all 4 corners. This is the most common problem. hope this helps and thanks for using fix-ya
Feb 15, 2010 | Washing Machines
The machine is brand new and shakes violently when on spin cycle
Hi. Most likely the leving legs are not adjusted properly. You can check this by pushing on the sides for you uint from all four corners indivisually. It the unit teeters on 2 legs then the legs are improperly adjusted. The easiest way to adjust them is to push on the cormer that causes any movement and rotate the adjusting leg downward. If the unit is already high then lower the longer legs intil the unit sops moving when you press on the TOP corners of the unit. Good luck. I think you can have this one solved easily.
Jan 10, 2010 | Washing Machines
Clothing Accessories Logo
814 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
