Question about Coffee Makers & Espresso Machines
Dropped tablet i dropped my tablet and screen got all kinds of cracked the charger i would have to hold a certain way to get it to charge and now it wont come on at all please help
  • 24 Answers
Screen probably has to be fixed and the charge port probably got damaged look in the port and see if the pins are straight if they are then some thing on the inside is damaged.
Posted on Dec 26, 2013
I have a dragon touch tablet but its not charging. I have to put force and hold it for a long time at a certain angle
Sounds like a bad charger port. If possible find a friend that has as 'like' tablet and see if that charger will work. I don't know of any device that needs to be in a certain position to charge. Since it's charging at an angle and with pressure, then it's probably not the charger, although it could be the part (of the charger cord) that you put into your tablet, usually from a high number of insertions/retractions or abuse.
May 10, 2015 | Dragon Touch Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
Trouble charging a Digland 10.1" tablet
Did the charger that you are using come with the Tablets? Many 5 volt chargers can only output a 0.5 to 1amp current, while a Tablet typically needs 2 to 2.5 amps charging current. So, if you're using a charger from some other device, then it's almost certain that it cannot provide a sufficient current for the Tablet, and the charger overloads, shuts down cools off, turns on again, overloads again, shuts down etc repeatedly - giving the exact symptom you are reporting.
Even if the charger did come with the Tablet, some of the Chinese ones are of very poor quality and cannot provide reliable service. A replacement charger rated to suit your Tablet (there should be something in the specifications that came with the Tablet listing the requirements for the charger) should solve your problem {:o)
Jan 01, 2015 | Tablets & eReaders
Its a crack inside my screen and i didnt know how to fix it so i opened my tablet to see what was wrong and i didnt see anythning. so i put it back together and its not turning on!!!!!!! please hel
(1) Is the battery charged? I'd connect the charger for at least 10 to 15 seconds anyway, while doing the following step.
(2)Are you holding the Power button long enough when you try to restart the tablet? It will need to be held down for a few seconds (perhaps 5 or 6) while you wait for the TRIO start-up screen to appear. Once it gets there leave the tablet to boot up fully.
If that does happen without further glitches should be able to go back to using the tablet as before.
(Was it working even with a cracked screen? Were you able to get the cracked touch-screen - I'm assuming that was what is cracked- to accept your fingertouch-inputs? Can you select items from all areas of the screen? If it was doing THAT, and it does it again NOW, I'd forget about the cracked screen , put a screen-protector on my tablet and press on ahead! Lucky dog!)
Nov 30, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
Why won't my new Proscan tablet charge properly?
The battery can't hold the charge. Defective.
Or the charger is defective and not outputting enough voltage.
This can be tested with a voltage tester. The charger should be outputting 5 volts.
A good purchase is an inexpensive voltage tester. Can be used for so many things.
Oct 11, 2014 | Proscan 10.1-Inch Internet Tablet,...
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
May 03, 2014 | Tablets & eReaders
My tablet wont turn on or charge i have to hold the charger ina certain way and i have to keep the charger up on something
One of the wires must be broken. Get a new cord and if it still doesnt work try getting a new wall power point.
Feb 23, 2014 | Kocaso M860W 1.2GHz 4GB 8" Capacitive...
Kurio tablet wont turn on
1) do you get a charge light?
2) Do you have to hold the charger on an angle to charge
3) Has it been dropped?
If yes to two or more of these questions it sounds like you need to bring it in for service. You can bring it in directly to our shop for a FREE evaluation or send it in for repairs... sounds like it either it has been shocked through a surge or drop and/or charge/DC jack is damaged.
Thanks,
Rising Son
Jan 31, 2014 | Kurio Touch 4S Handheld
Coffee Makers & Espresso Machines Logo
14 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
