Question about Konica Minolta Office Equipment & Supplies
Bizhub c 3102 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Model number would help
Posted on Jul 05, 2016
I have a problem with my konica minolta bizhub c451 giving error Code C 3102
c3102 for Fuser Unit abnormality.
Check Fixing Unit and its Gears , also the drive gear on body.
Reset by Switch On Holding Utility/counter Button for 10 seconds.
Touch TROUBLSHOOT and restart by Power off and on
Jul 07, 2017 | Konica Minolta Office Equipment & Supplies
Where can i find the fusing unit with pictures about c-3102 bizhub c650
The fusing unit is located on the right side of the machine, open the right side door, not the duplex door the bigger one. you will see a shinny belt do not touch as that puts the image on the paper. The fuser unit is right above it. It can be hot so power off to remove it. your code is for the fuser did you try to reset it??
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jan 03, 2017 | Konica Minolta BizHub C650 Copier
Reset error code 3102 on Konica Minolta bizhub 6500
drive issue for the fusing motor, get a technician to look at it
Jun 25, 2014 | Konica Minolta Bizhub C 6500 Copier
Bizhub c650 fehlercode c3102
C 3102 - Communication sistem setting error.To reset :
Turn OFF the copier,keep pressed Utility/Function key and turn ON.Keep pressed the Utility key when Trouble reset message apaire on screen.Touch the message,turn OFF ,wait 1 minutes and turn ON.
If the code persist remove the fusing unit and under fuser unit in right side upper is located 2 sensors under plastic knob.Clean the 2 sensors.
Dec 22, 2013 | Konica Minolta Office Equipment & Supplies
C 3102 error code
replace the fuser unit
Dec 21, 2013 | Konica Minolta Bizhub C550
I have an error C0094 what does it mean
You have Minolta dialta CF 3102
The C0094 code -2nd transfer roller separation.Clean using vacuum cleaner the transfer unit and the electrical contacts.
Feb 11, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
3Com 3102 unable to connect to NBX 100
The problem is licensing for a 3102 phone. I doubt an old NBX 100 has a group 2 license. The 3102 requires a license to run unlike the 1102 or 2102.
Jan 07, 2009 | 3Com NBX 3102 IP Phone
Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Jan 10, 2008 | Konica Minolta bizhub C250 All-In-One...
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
