Question about Microwave Ovens
Inverter manual panasonic mid 043 wix - Microwave Ovens
Panasonic Inverter Manual
go please to www.fitness.manualsonline.com or www.retrevo.com and download free.
God bless you
Oct 31, 2013 | Microwave Ovens
Microwave stops mid cycle
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Dec 27, 2012 | Panasonic NN-T664SF Microwave Oven
Need a service manual for Panasonic inverter assembly A606YM30
See the safety file here first.
Normally it's best to look up the microwave oven's service manual by model number and go from there, but since you didn't list that, this should help.
I have several publications including manuals and bulletins in my files covering Panasonic inverters. They are here:
http://031d26d.namesecurehost.com/mwd/bulletin_inverter_repair_kits.pdf
http://031d26d.namesecurehost.com/mwd/inverter_files.txt
http://031d26d.namesecurehost.com/mwd/panasonic_Inverter.pdf
http://031d26d.namesecurehost.com/mwd/panasonic_inverter_and_info.htm
http://031d26d.namesecurehost.com/mwd/panasonic_inverter_microwave_testing.txt
http://031d26d.namesecurehost.com/mwd/panasonic_inverter_models_trouble_codes_sm.pdf
http://031d26d.namesecurehost.com/mwd/panasonic_inverter_parts.txt
http://031d26d.namesecurehost.com/mwd/panasonic_inverters.pdf
http://031d26d.namesecurehost.com/mwd/Panasonic_NN-G62BH_A606Y4T00AP_inverter.pdf
You can order Panasonic parts from Encompass here.
Dec 11, 2012 | Panasonic Microwave Ovens
My panasonic inverter microwave model no NN-T523M switchs off after 5 secondsno matter what setting. the digital screen says consult manual, which has been misplaced
You can find Panasonic owner's manuals here.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 7 seconds, it has a problem with the inverter.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
If you decide to replace your inverter, you can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
May 15, 2010 | Panasonic Microwave Ovens
My GE microwave will only run for 21 seconds and then it shuts off. Even if I try to heat something by running it for 21 seconds multiple times, it doesn't get anything warm.
I've heard of this is Panasonic microwaves but not in GEs.
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well your symptoms "only run for 21 seconds and then it shuts off".
For those readers with a a Panasonic that stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Nov 27, 2009 | GE Profile 1.5 Cu. Ft. Mid-Size Microwave...
Need a manual for a panasonic inverter combi microwave oven model number NNA514A
my microwave is saying h98 what does that mean. it's a panasonic inverter.
Aug 05, 2009 | Panasonic Microwave Ovens
INSTRUCTION MANUAL FOR PANASONIC INVERTER NN-SD376S
Desperately need
INSTRUCTION MANUAL FOR PANASONIC INVERTER NN-K593MF. please help
Jul 20, 2009 | Microwave Ovens
Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Thankyou
Mat
Jun 10, 2009 | Panasonic MCM INVERTER
USER MANUAL
You can download many Panasonic models' owner's manuals free here.
If yours is not there, you can order one here.
Nov 23, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
