Question about Hotpoint RB526 Electric Kitchen Range
Bad line display says bad line and beeps
I plug my gas stove in and the display says bad line and beeps steady
"bad line" error means the control panel is not seeing a proper voltage to the oven. Have the power connections checked with a voltmeter all the way to the control panel. If voltage is present, you may need a new control. 25316221-dz1fkxf1fwolart5ai0divhk-4-0.jpg
Dec 10, 2014 | Hotpoint RGB745 Gas Kitchen Range
Tip
Beep Codes (Different BIOS) " What they mean "
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
IBM POST Diagnostic Code Descriptions
Code Description
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Colour/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Colour/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
on Dec 30, 2009 | Computers & Internet
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
My fisher paykel nautlis dishwaher display error code F1
What is the Model #? If both drawers, if a double, display F1 and won't shut-up then the flood switch is tripped and you have to unplug it to keep it from beeping and the drain motor running. The causes for the F1 fault can be numerous but not excluding bad lid lifts, broken link support, cracked drain line and wrong soap. Call F/P
Jul 19, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
Display
Have you tried other ram.Also try a graphics card.
May 06, 2009 | Intel D845GVFN Motherboard
4 beeps 2373 laptop
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
Code Description
2-_-_ Faulty Memory
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
At POST I get 2 short beeps
it depends on the bios chip maker Here's some other beep codes:
for Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly
Short continuous beeps: Bad power supply
AMI BIOS:
1 short beep: DRAM flash error
2 short beeps: DRAM ECC check error
3 short beeps: DRAM detect error
5 short beeps: CPU error
6 short beeps: Keyboard error
8 short beeps: Video card error
1 long and 3 short beeps: Bad DRAM
1 long and 8 short beeps: Video card error
Invoking Beep Codes
If the computer is actually functioning and the computer beeps continuously, then there is a problem with a voltage on the power supply being incorrect or the CPU overheating. IMMEDIATELY go into the BIOS and check CPU temperature, fan speed and voltages
BIOS Beep Codes
Annoying isn't it? You have built your computer you switch it on and then nothing happens except a few beeps from the PC speaker. Frustration sets in as you try to figure out what is wrong with it. If you didn't already know the computer has already told you the problem. It can't speak of course but it can direct you to the problem. Its all in the beeps. The BIOS can recognise when the problem occurs and sends a signal out to send a certain amount of beeps through the speaker. These beeps then tell you the location of the problem.
Unfortunately not all the BIOS' use the same codes as each other. Two of the main BIOS manufactures AMI and Award (now Phoenix) have different codes for there errors.
AMI BIOS
# of Beeps Error Description
1 Refresh Failure The memory refresh Circuitry is faulty
2 Parity Error Parity error in the Base (1st 64K) of memory
3 64K Base Memory Error Memory error in the base memory (1st 64K)
4 Timer Not Operational Timer 1 is not functioning (also caused by error in base memory)
5 Processor Error CPU error
6 8042 Gate A20 Failure Unable to switch to protected mode
7 Processor Exception Interrupt error The CPU on the CPU card generated an interrupt error
8 Display Memory Read/Write Error Video adapter is missing, incorrectly seated or has faulty memory
9 ROM checksum error The ROM checksum does not match that of the BIOS
10 Coms Shutdown Register Read/Write The shutdown register for coms RAM has failed
11 Cache Memory Bad The cache memory test has failed. Cache memory will be disabled. *** DO NOT enable it ***
With the first 3 beep codes, its well worth re-seating the memory just to make sure that it's in correctly. 8 Beeps is probably the most common in my experience. Can be caused by a badly seated Graphics card. If you have re-seated it then check with another Graphics card in the board.
Always check for loose components before sending the board back as this is the main cause of errors on the POST.
Award BIOS
Award states that they now only use one beep from there BIOS. This beep is one long beep and then two short beeps. This indicates a graphics card problem. Any other beeps should be treated as a RAM problem first and then the board sent in to be inspected.
The reason that the Award BIOS only uses the beep code for display problems is that it tries to display the error on-screen if at all possible. If the BIOS cannot initiate the display adapter then this causes the BIOS to make the beep code for a display error, which must be corrected before any other errors can be determined. Memory Test fails and hard disk failures etc will all be displayed on screen
IBM BIOS
The IBM BIOS works with Short and Long beeps as well as the Award BIOS. However the IBM one does still have codes to work from.
Beep Code Error
1 Short Beep Normal POST, System booted OK
2 Short Beeps POST Error - Code on Display
No Beep Power supply or Motherboard error
Continuous Beep Power supply or Motherboard error
Repeating short beeps Power supply or Motherboard error
1 short, 1 long beep System board error
1 long, 2 short beeps Display adapter error (MDA/CGA)
1 long, 3 short beeps Display adapter error (EGA/VGA)
Phoenix BIOS
The Phoenix BIOS works on a slightly more complicated manor than the others. It does display an error code for you and produce a series of beeps. This BIOS produces its beeps according to the hexadecimal code the error produces. The Phoenix BIOS has many different codes for its possible errors and so many different beep codes. Rather than list the entire section here, I have provided a link to the official PDF file containing the codes and how they are derived.
Phoenix BIOS Post Codes
System board errors should be looked at by a specialist, Again always try to re-seat components to ensure they are in correctly. If necessary take all components out except for the RAM CPU and graphics card, then try the system. Re-seating components is the number one fix for getting past the POST screen. One badly seated components can cause the entire system not to function. so pick out your bios and follow the steps above to diagnose .hope this helps
Jan 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
GE JBP66 Self Cleaning Radiant Range
Your range is wired improperly. Hot wires go on the two outside terminals.
Nov 04, 2008 | GE JBP24 QuickClean Electric Kitchen Range
As soon as Windows xp home began to load....
Hi Obenour,
Two beeps than a short pause than two beeps again repeating means. A memory parity error has occurred in the first 64K of RAM. The RAM IC is probably bad. Best thing to do is download a memory testing bootable software for a floppy disk. This program works out side of windows. It will test you're memory.
http://www.memtest.org/
You'll need display for this. If you have more than one bank of memory installed, remove all but one. Check your manual & see which DIMM slot the memory should be in as a single DIMM. If you only have one DIMM replace it. Test you're monitor on another system or laptop. (Checking it on another system, verify’s its good).
Monitor display good! Than check video card (If you added an 8x AGP card). Remove & reseat the card. Check again for good display. Still no decent display? Windows will not install file correctly with bad memory. You will not receive clear display on your monitor.
Aug 09, 2008 | SIS741GX-MN Motherboard
Hotpoint RB526 Electric Kitchen Range Logo
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
