ESC 945P-A VER 2.0A - Computers & Internet
My graphics card is not being recognized. Im using a ECS 945P-A Ver: 3.0 motherboard which has no on board video output. im using a Zotac Technology GEforce 7300 GT graphics card too. Do I need a powe
I don't believe that graphic cards of that level need PCI-EX power directly from the power supply (using a power supply cable with a PCI-EX connector). This is a good thing, but that's because this is a low-level card--one that likely needs nVidia legacy drivers: It's likely that active driver support has ended. (The same is true for legacy AMD/ATi cards--and other more ancient cards, as well. ((PCI or AGP) Sabre, 3DFX, etc.)
If you're using the VGA port--perhaps the card's DVI port is needed for initial install, instead--or vice-versa. (You'd need an adapter or different cord to run to a VGA monitor or TV's VGA port .)
Rarely, two VGA ports might exist on a card, instead. In any case, the port needed likely isn't the one connected (with a ribbon cable) to the PCB on the video card. (Once you get a workable video card driver installed, then you should be able to use either port.) Try all usable ports before finding another possible solution....
Apr 05, 2014 | ECS 945p-a Intel 945p Socket 775 Atx Mb...
I need a wiring diagram so i can wire my board correctly
Hi!
There are 2 versions for your motherboard, refer to the one you have:
Ver. 3.0 - here
Ver. 1.1 - here
The manual contains all the info you need for your motherboard!
Best regards,
Pelu.
Jan 14, 2011 | ECS 945P-A (V3.0) Motherboard
Access Toshiba BIOS
WHEN YOU FIRST TURN THE COMPUTER A LIST OF INSTUCTIONS WILL POP UP FOR 5-9
SECONDS, YOU NEED TO PAUSE THAT PAGE SO YOU CAN GET THE RIGHT ACCESS.
HERE ARE SOME DIFFERENT COMBINATIONS TO TRY.
DEL BEFORE TURNING ON HOLD THIS KEY DOWN UNTIL YOU HEAR THE BEEPING NOISE.
F2
F1 DURING BOOT
F10
RESET DEPRESS 2 TIMES
CTRL ALT ENTER
CTRL ALT ESC
IF NONE OF THESE DO NOT WORK THAN YOU NEED TO BUY THIS GUYS BOOK VER COVERS BOIS 2006 AND NEWER
I HAVE THE OLD ONE. VER 1997
THE BIOS COMPANION BY PHIL CROUCHER
May 12, 2009 | Toshiba Satellite P105-S6177 Notebook
Can't run long
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
jashim15
Apr 03, 2009 | ECS 945P-A (V3.0) Motherboard
Sound driver for 945p-a ver 1.1.can u help me
Dear user,
All the drivers can be found here:
http://ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=525&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
If you can't find it here look here for second chance:
http://europe.asrock.com/mb/download.asp?Model=ConRoe1333-D667%20R3.0&s=&T=D&ID=425
Nov 15, 2008 | ECS 945P-A (V3.0) Motherboard
PLEASE GET A SOLUTION TO MY PROBLEM
Hi - You can download the software from the link underlined in blue below:
m791g
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 15, 2008 | ECS 945P-A (V3.0) Motherboard
Wont power up ecs motherboard
Your 4-pin power connector supplies voltage to your CPU through some series of MOSFET transistors. First try to disconnect your CPU from the socket and power up your motherboard. Your CPU might be toasted. MOSFET transistors might be bad. Also look at your big caps around the CPU. If they have bubbled tops, you need to replace them.
Good luck
NetSalem
Jul 17, 2008 | Intel Motherboard
Everything works, but no display
Try a different stick of RAM. Like a smaller amount. try 512MB and see what happens. if 512 works, try the 1 of the 1GB sticks so you can still have atleast have 1GB.
Jun 11, 2008 | ECS 945P-A (V3.0) Motherboard
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
