Tv on standby whe switch on no picture comes up
I have an acoutic solution tv model lcd32805 has not been in use for 4 years we tried to set it up yesturday the blue light is on but not pict comes up
  • 7 more comments
  • sandra figueira Dec 26, 2013
    Hi i will ask my son to take a pict when he gets home . do you think it will b expensive to fix?thank you
  • Csquared Cole Dec 26, 2013
    It depends on what the issue is. Make sure it's unplugged when it's disassembled and do not touct the bottom side of any of the logic boards.
    Touch*
    ok thanks
    hi we have tried to open the bavk of the tv but we could'nt
    Add a Commentand did'nt want to try to hard just in case we break it
    sorry
    thanks for your help
    Look closely you may have screws hidden around the tv stand area. Lay the tv flat on its screen and look for all screws around the back cover and around its edges.
    Look for all bolts once the plastic cover is off you will see a metal cover remove that then go wild with the photos.
    New Friend:
  • 39 Answers
Do you have sound?
Posted on Dec 26, 2013
Testimonial: "no sound either"
  • 1 more comment
    no sound either
    I agree with others this unit is not fully starting. I would beliebe you may have a bad capacitor in that tv it is something to expexct after 4 or so years. I wish you could open it up and take pictures for me.
    believe*
jerryg50
  • 1689 Answers
SOURCE: plasma wnt stay on
I have had this problem in some models of plasma sets before. In most cases the power supply and main drive boards had to be replaced. In a small number of cases the failure was the screen itself.
In all cases, the cost of the repair was expensive. For the screen failure, the set was scrapped.
Jerry G.
Posted on Apr 12, 2008
  • 41 Answers
SOURCE: tv stuck on standby
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
Posted on Mar 30, 2009
  • 187 Answers
SOURCE: Can turn on to red light and get blue light, but no picture
The mainboard needs to be replaced
Posted on May 27, 2009
SOURCE: TV switching to standby
Hi.i had exactly the same problem with my bush 37 inch lcd tv and i took it to a friend of mine who is a t.v electrician he said it was a component in the back of the tv which he replaced and its now working fine.
Posted on Aug 02, 2009
  • 1768 Answers
SOURCE: TV won't switch on
1. Your Tv is in need of service.
It sounds like the tube that give light to the screen for visual is defective and needs replacement.
2. The power supply circuit needs repair. Possibly a capacitor or diode has failed in the start up circuit
Posted on Mar 19, 2010
Testimonial: "Thank you much appreciated, by any chance do you know how much this repair should cost? Chris Raby"
TELEVISION IS IN STANDBY WONT SWITCH ON TO PICTURE
First is the set should have a 1 year parts and or labor warranty--second: in order to offer advice or give help I need to know brand and model number.
Dec 06, 2012 | Televison & Video
Hi, I switched off my Samsung TV last night as usual, and when I tried to switch it on this evening it wouldn't switch on.I tried unplugging it and turning it on, but the red power light on the b
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo. 11_6_2012_3_22_05_pm.jpg
Nov 05, 2012 | Samsung HP-R5052 50 in. Plasma HDTV
50PJ350 turns off after being turned on
A general answer here and some information:
I see so many here with no sound/nopicture issues:
ISSUES:
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Apr 24, 2012 | LG 50PJ350 50 in HD-Ready TV
My HP Plasma is about 4 years old. Picture was great, until one day I turned it on and 75% had not color. The rest had picture and almost looked like it was going to come back on but no such luck. ...
this will reset all settings with TV in standby press INFO / MENU / MUTE / STANDBY on remote the TV will come on with a menu DO NOT CHANGE ANY OTHER SETTINGS only use down navigation key to move to were it displays reset then press RIGHT NAVIGATION key the TV will reset press standby to exit menu and then retune TV.
but if otherwise
Tries websites like Shopjimmy.com,Ebay.com to buy parts for the replacement.
Hope this work
Aug 02, 2010 | HP PL4260N 42 in. Plasma HDTV
Samsung 50" r p tv switches off
Replace your Lamp BP96-01073A Fox has them $109.00 1-800-227-5369
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
Jan 12, 2009 | Bush 5693D 24" TV
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
