Antenna manuals HYGain 64B-S - Audio Players & Recorders
Hygain AR-500 rotator
Please let me know exactly what your question is?
May 10, 2014 | Hy-Gain AR-500 Rotator for HF/VHF Beam,...
can be paper sensor its faulty. reload with diferent paper and reset printer to factory default. try to print pause test without printer connecter to computer.
Feb 17, 2014 | Zebra 2746e Thermal Printer
Can you run office 32 bit on a windows 64 bit operating system?
You have 32-bit Office installation package (CD/DVD/file) and 64-bit Windows operating system. Is it correct?
General answer is YES, I can install a 32-bit application on 64-bit OS. I have exactly same situation in my laptop. Both 32-bit LibreOffice and 32-bit MS Office are installed on W7 & W8 laptops and work well.
But NO vice versa. The 32-bit system does not allow to install 64-bit application. The 32b system does not support 64b instruction set required for 64b applications.
My experience is confirmed by many other users:
Office 32 bit to Windows 7 64 bit
Jan 29, 2014 | Microsoft Windows 7 Professional for PC
We already installed ISeries Client to our windows 7 pcs and installed ncomputing x350 model. We cannot use the other 3 terminals for iseries session due to keyboard problem. can somebody help me on this
About the time you posted this, there was an update for the NComputing software, it went from version 5.x to version 6.x for Windows7 32b. Try that update. Also, if you have Intel Active management installed on your PC, make sure you disable that. Don't uninstall, simply disable it by going to device manager ' Ports, right click on IAMT or SOL on Com3(if it's there) and disable. Also if you're running Win7 64b, the same vSpace v6.x will work for both 32b and 64b.
Jun 28, 2011 | NComputing X300 3 User Expansion Kit...
Window 7, 64b/t
HP support has software available for Win 7 x64. Also under "Useful Links" there is an HP automatic driver "checker"
HP Color LaserJet 2550LN Downloads
Dec 30, 2009 | HP LaserJet 2550Ln Printer
I need a new driver for windows 7!!! Vista 64b
you need to find out if behringer has a driver upgrade for win.7 if not you are out of luck until they come up with 1//
Nov 15, 2009 | Behringer (UCG102) Sound Card
4 ohm connection for realistic STA-64B
I have a pair of Cerwin Vega 123's as they are 4 Ohm BUT just one pair only as this will have your amp working harder!!!
Apr 15, 2009 | Audio Players & Recorders
Drivers for Mustek 1200 UB Plus for Vista 64b
I have a Mustek Plug-n-Scan 1200 UB Scanner. I can't still install it under Windows Vista 64 bit.
Feb 03, 2009 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Belkin n wireless
Open the router control panel using Internet Explorer. Open wireless page and look for security option. Simplest security measure is setting up a 64b wep encription key it is made of 10 exadecimal numbers (0..9-A..F). It is still a good option to secure home based network. Refer to the router manual for information on how to open the router control panel using internet explorer. Remember to save all changes made to the router before restarting it.
Hope it may help!
Feb 14, 2008 | Computers & Internet
23 people viewed this question
 Grubhead
Grubhead
