Question about Toshiba 65H81 65" Rear Projection Television
Tv after power surge
I have a 65H81 hd toshiba had a power surge and fried main power board. Can that weaken the rest of the items if that is the only wrong. I don't want something to go wrong later because insurance is taking care of it. would it be better to replace the tv
    President:
  • 788 Answers
I have been servicing televisions for over 20 years and I have never had any luck on a lightning strike repair. There are too many variables in electronics and IC's and these repairs can be very lengthy. I would ask for a replacement rather than a repair.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If not then please comment to this post and I will try to help you further.
Posted on May 17, 2009
  • Toshiba Master
  • 5,568 Answers
There isn't really an absolute answer to your question. The power supply affords some protection to the rest of the set when the components designed to prevent short-term power spikes activate but their primary purpose is the protection of the supply. There is surely a fuse on the line-side of the supply, then there are two more devices normally included (they cost little) that will force the fuse to blow if a certain line voltage peak is encountered, a type of resistor that is actually a semiconductor that has little effect until its design is exceeded; it then looks electrically more like a  dead short, causing the fuse to blow. The other device doesn't do much after the first few cycles of AC and is there to reduce 'inrush' current. Well-designed supplies will have fuses on the output side of the supply that protect specific voltages and circuits.
Could the low-level circuits have been affected?  Yes, but in some cases, only a working supply and time would show up some kinds of failures.
In addition, I always include the suggestion pasted below:
If you live in an area of frequent lightning strikes, investing in a 'whole house' surge arrester makes sense.
These are installed in the main breaker box and any brand I've seen comes with a $10-25,000 insurance policy to replace any dead appliances that fail despite the surge protector.
They cost $150-250 US plus installation which you can save if you are afraid to DIY.
What needs to be changed
The lightning damage is through the cable box section, i would try a new main board first.
Oct 23, 2017 | Samsung LA32A450 32 in. HD-Ready LCD TV
Toshiba TV dead: is there a fuse inside? Toshiba 24AF46 is dead after a thunderstorm and nearby lightning. Plug sparks when I plug it into the wall. Nothing happens on the TV. No sound, nothing when I hit...
Yes,there is a fuse in inside on the tv main pcb board near the power a/c cord.But if the tv have sparks,main pcb board could have more other components fries too.If tv less 10 years repair it by a shop,more than that should buy a another tv.
Jun 09, 2011 | Toshiba 24AF46 24" TV
Tv will not turn on....power button only flashes...what's wrong????
There are a number of fuses on the main board about 10. One is and glass fuse were the power cord is, that one is ok because of flashing. the other ones are solder-in and you will need a meter to check them, they start with an F---- and some numbers and are marker on the board. Good Luck
Aug 14, 2010 | Toshiba 65H81 65" Rear Projection...
I have a Toshiba 32HLV66 with built in DVD with no picture.
main board part number is 75004719 you should be able to google it to find it.
Sep 03, 2009 | Toshiba 32HLV66 32 in. LCD TV/DVD Combo
Toshiba 65H81 Displays static, however menu screens fine
Well in this case you may have an issue with your Video Board, if the static showed on the menu, then the issue would have been with your DMD Board, but not in this case.
Jul 27, 2009 | Toshiba Televison & Video
RED POWER LIGHT BLINKS
Red power light blinks and tv will not turn on it is a 65h81 Toshiba HD
Jun 19, 2009 | Toshiba 65H81 65" Rear Projection...
After power surge my tv (toshiba 52') will not power on
after a power surge if you dont have in on a surge protector it probably fried the main board in the tv so it wont work anymore..woudl probably be cheaper to buy a new tv than to try to repair the one you have now
Dec 15, 2008 | Toshiba 57H93 57" Rear Projection HDTV
PD 0074
That is the deflection board which is no longer available. I have a source that rebuilds circuit boards but that item would be around 350.00 to rebuild the entire deflection board. Heres the link if youd like to contact them.
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 blinking power light
Hello
I have the same thing going on with mine. What it is the SLR main Reg. is bad. The only way you can fix it is you can't put just one part in it you have to replace one of the boards. When you open the back panel up you will see three boards in a roll the one that needs replacing is the power board you have to get the model number. My Tv is a 65 HD model 65h81 the board on mine has a part number of PD 7400 yours will have something like that. Well let me know how it's goes my E-Mail is kenjr1@iwon.com
Feb 14, 2008 | Toshiba 65H81 65" Rear Projection...
Str reg.
No need to take the front screen out. The power deflection board is messing up with that red light.
Nic
Aug 19, 2007 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 65" Rear Projection Television Logo
165 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
