Mission m73 with a woofer which seems to have gone dead
I have had a pair of Mission m73 speakers for about 10 years, and noticed yesterday that the left channel woofer isn't emitting any sound. I've checked the connections which were OK, swapped the speakers around and right works where left didn't and left still doesn't work in right's position, so I've now dismantled the woofer to check visible damage and try the AAA battery pop test... and I think the woofer is definitely dead. I've been reading on forums this morning and people tend to say that woofers don't just die like that, and the tweeter will normally die first... So what's my problem, and how do I solve it? Please? Can i replace the woofer? They seem hard to source on internet?
    Problem Solver:
  • 5 Answers
I use to have some warfdales that did that, and generally it was the cross over unit that would blow a fuse, if fitted.
Posted on Dec 26, 2013
  • Chris Ackland
    Chris Ackland Dec 27, 2013
    Thanks for the advice Tim. Do you know where I'd find the crossover unit and associated fuse(s), and what they'd look like?
3 Suggested Answers
  • 4234 Answers
SOURCE: Lost woofer in one cabinet.
I'm not familiar with your specific model, but some of these have fuses for the woofers. Check for a blown safety fuse. Also, verify that the connections to the crossover board are in good shape. These crossovers are not that complex and don't usually fail. Keep us posted on what you find.
Dan
Posted on May 29, 2008
  • 867 Answers
SOURCE: JBL speaker's woofer occasionally cuts out - tweeter still works.
Your driver has a damaged voice coil, you can either find a speaker repairer to replace the voice coil or find a replacement driver to fit.
Posted on Mar 07, 2012
How come the sounds from my main speakers coming out only on the small soft ball.
you need to either add the tweeter/bass bridges or your bass drivers are gubbed
Nov 23, 2014 | Mission M73 Main / Stereo Speaker
No bass in righthand speaker
First try swapping the cables and put the left speaker cables in the right hand amp output and the right speaker in he left output. If the problem stays in the right hand speaker and does not move to the left as I suspect should, then it is a problem with your speaker crossovers. You may have to open up the speaker and check the wiring and then crossover. If the problem changes and appears in the left hand speaker you have an amp problem.
Jun 08, 2014 | Mission M73 Main / Stereo Speaker
No sound from the main cone mission m73
It sounds to me that there is something wrong with the crossover unit inside the speaker. These tend to use non-polar capacitors these sometimes fail, but it depends on how sophisticated the crossover is. It could use semi-conductors as well, which also fail.
Dec 11, 2011 | Mission M73 Main / Stereo Speaker
Q: no high frequenties are heared,tweeter/filter problem ? how to open the box to replace components ? it is a Mission M73 loudspeaker
To open the speaker, remove the rubber 'grips' from the holes that hold the protection screen. Screws are behind them...
Jul 16, 2011 | Mission M73 Main / Stereo Speaker
The cone is detached from the coil and the speaker is not working
No other solution than replacing the entire driver. Contact Mission's US importer for parts cost and availability.
http://www.missionspeakersusa.com/WARRANTY_PARTS.html
Mar 31, 2011 | Mission M73 Main / Stereo Speaker
I just got some mission 73 speakers how do you know if they are blown ..thanks gary
Just connect a 1.5 volt battery to the plus and negative terminals. You should hear a pop in each driver.
Oct 07, 2010 | Mission M73 Main / Stereo Speaker
Mission 780s (from early 1990s) tweeter gone?
Hi there.
Do you have the make and number on the back of the magnet?
Check if the tweeter is at all available on the net!
To have it repaired is also an option.
Iceman.
Nov 05, 2009 | Mission 780 Main / Stereo Speaker
No Woof
If these are Mission 780s your talking about, you're not the only one. The woofers supplied with the speakers originally have a known design/manufacturing flaw causing them to go "open circuit" after a few years use. The good news is that IAG (who now own Mission) can supply you with a pair of replacements for about £45 plus postage. (You'd be forgiven for thinking they should supply the replacements for free given the cost of these speakers new and the fact this is a design/manufacturing fault). Replacing your woofers is easy. Take off the front baffle. Remove the four rubber plugs that the baffle attaches too, and take out the 4 screws you'll find behind them. Now ease off the plastic moulded front pannel. Remove the four screws holding the woofer in place. Pull the spade connectors from their tags on the back of the speaker. Put the new woofer in by following this proceedure in reverse.
Aug 03, 2006 | Mission 780 Main / Stereo Speaker
260 people viewed this question
 Grubhead
Grubhead
