Question about Nikon D40x Digital Camera
Camera is saying "Memory card is locked. Slide lock to "write" position."
Okay well when i try to take pictures it tells me "Memory card is locked. Slide lock to "write" position." What is going on? and how do i fix it?
  • 9 Answers
If you remove the card from the camera, there is a little switch on the SD Card. There is typically a label that shows which direction is locked. If not, switch it to the opposite side. This should solve the problem. Otherwise, there could be a problem with your card. I hope this solves the problem.
Posted on May 17, 2009
My memory card's slide lock so that i want unlock how can possible?
Posted on Oct 04, 2010
Memory card is locked and cannot delete pictures
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 12, 2014 | Kodak EASYSHARE V1253 Digital Camera
Camera saying memory card locked slide lock write psition
The Nikon N75 is a film camera. It doesn't use a memory card at all.
If you're referring to some other digital camera that does use an SD/SDHC card, look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 21, 2013 | Nikon Photography
Memory card locked
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 22, 2012 | Sony DSC-TX100V Digital Camera
Pentax camera card is locked
Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 02, 2012 | Pentax For Optio M85 E85 E60 Digital...
When you turn camera on or try to take picture it says card locked
The memory card in the camera has been locked. if you remove the memory card, you will see a small tab on the card and it is likely switched to the "lock" position. This can happen easily by accident if you are handling the card. Simply slide the switch on the memory card away from the lock position and you should be back in business.
Apr 17, 2011 | HP Photosmart M425 Digital Camera
Samsung sl600 is saying card locked when I try to take a picture
Remove the memory card from the camera, along one edge you will see a tiny switch, slide it towards the contacts to unlock the card, the switch that is in the farthest position from the contacts is in the locked position to prevent deletion. Now! if the card is in the unlocked position slide the switch back and forth to reset the card. If that fails the card should be replaced.
Mar 03, 2011 | Samsung SL600 Digital Camera
When I try to take a picture it says "Memory Card
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 19, 2011 | Samsung L100 Digital Camera
My memory card is write protected. when i turn on camera the screen is saying it is write protected, i can't take pictures or delete pictures
Hi. Thanks for your question.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Please don't hesitate to ask more questions if this is needed. Thank You for using FixYa.
Jan 10, 2011 | Nikon COOLPIX L18 Digital Camera
My nikon camera says "Memory
Remove memory card from camera and slide lock in memory card (check photo).
Dec 02, 2010 | Nikon View DX (25243)
When i try to take pictures my camera says card locked.
It's the memory card or SD card you have in the camera. (it sounds like)
Try taking the SD card out and if you look at it closely there is a little switch/ thing you can slide. Slide it to the other side, put it back in your camera and try again. Hope that helps
Jun 02, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
Nikon D40x Digital Camera Logo
2,692 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
