Question about Maytag Neptune FAV6800AW Top Load Washer
Won't pump out water
Washer make a makes a vibrating of huming noise while running. At the end of the wash cycle It will spin but will not pump out water. When through spinning it sounds like the washer stops bu tyou can her the timer running. It will go into the rinse cycle from there. I removed the bottom front cover and can see the pump turning
Thanks
  • dh1200s
    dh1200s May 11, 2010
    Hello rcahill41018,
    You should let everyone know your machine Model and Serial number. There may be a better forum to post in for support. From what you describe it doesn’t sound like a FAV6800AW or FAV9800AW.
Loaded in truck hauled to repair shop.
Posted on May 20, 2009
Kenmore washer 80 series does not drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump: Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Asko 620 washer won't drain well with heavy load
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
Oct 08, 2012 | Asko W6021 Front Load Washer
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
I have a fisher and Paykle GW612 washing machine, it won;t drain the water and won;t do the spin cycle. It now is making a huming noise. I think it is the motor that has an issue?
There should be a tech sheet located underneath the control panel that has the procedure for putting the machine in "diagnostic mode" and you can easily run the water pump by itself. Listen for a "hum" sound- If you hear a hum instead of a running water pump, then something is keeping that pump from turning for sure.
If this is the case, then you would need to check your water pump. It is located underneath the machine in the right front corner (as viewed from the front of the machine)
There is a black plastic external cooling fan impeller that you can spin with your finger (of course unplug the machine first) and see if the pump spins freely. You should also examine the pump for signs of leakage or corrosion. You may simply have an object that was left in someone's pocket that has become lodged in the pump. Pump removal requires no tools, however you need to first bail out as much of the remaining water in the wash tub as possible.
Jan 15, 2011 | Washing Machines
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
132 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
