Question about FUJIFILM Instax 210 Film Camera
Stuck lens When I turn the camera on the shutter does not open and the lens appears to be stuck. An error message is on the screen. I have tried putting in new batteries but nothing seems to be working.
  • kakima Dec 26, 2013
    What does the error message on the screen say?
  • kate
    kate Dec 26, 2013
    It's a flashing E with arrows pointing around the screen
    Problem Solver:
  • 28 Answers
Hi, 210 wide camera lens stuck is cause the spoil gear. This is commonly happen to physical damage camera.
Posted on Jan 15, 2014
  • Violetta Cogoni
    Violetta Cogoni Oct 19, 2015
    ok... and what's the solution?
The camera screen stays black, and I can not see anything through viewfinder or on the screen. When I take pictures, they are completely black. Is the camera worthless now?
It sounds like the CCD has gone bad, in which case, the camera is not getting repaired, since it sits on the main circuit board, and you would have to buy the entire board, plus pay the extensive labor. There may be a chance that the shutter is stuck closed, and you might try some suggestions I ran across on a web blog. The blog deals with error messages and lens assembly problems, so it's worth trying:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Hope this helps.
Jul 07, 2010 | Canon PowerShot S3 IS Digital Camera
Shutter appears to be stuck closed.
Theirs oil on the shutter blades causing it to stay closed, Thats why you can't see though the lens or the viewfinder also, This comes from the grease from the zoom assy, It's a major job to fix it, Has to be fixed by a repair shop
Jun 04, 2010 | Canon PowerShot S3 IS Digital Camera
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
Lens won't open
Dec 07, 2009 | Canon PowerShot S2 IS Digital Camera
Error Message
Try to take off the battery and reset the camera. You can also try to remove the lens and check the mirror opening..see if there is some thing stuck there. You can try to click the shutter while the lens is removed. If this procedure didn't work I suggest calling Nikon for further repairs.
Sep 25, 2009 | Nikon D60 Digital Camera with 18-55mm lens
The LCD screen has gone blank...the other features seem to be fine...but can't click pictures any more...they appear black..
Jul 24, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Screen does not show images
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 27, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
My screen is black or blank
I think you mean your automatic lens cover opens. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Feb 23, 2009 | Nikon COOLPIX L18 Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
FUJIFILM Instax 210 Film Camera Logo
831 people viewed this question
Top FUJIFILM Photography Experts
J.D. Browning
J.D. Browning
Bill Boyd
Are you a FUJIFILM Photography Expert? Answer questions, earn points and help others
