Question about iLO DVDR05 DVD Recorder
Ilo DVDR05 Vibration and loud humming noise
This doesn't happen every time I play a DVD, but sometimes once the tray is closed there is a vibration that also emits a loud humming noise. So loud that it can be heard over the volume of whatever is playing. This stops once the tray is open. Thanks in advance for any suggestions?
    Sergeant:
    Champion:
  • 255 Answers
I experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
Posted on May 18, 2009
I cannot play a dvd movie or record a tv program in ilo dvdr05 recorder, what might be the problem?
1: Get a movie and some popcorn.
2: Make sure the DVD player and the tv are turned on.
3: Push the button on either the front of the player or on the remote to open the player door to load the disc.
4. Put the disc on the tray that pops out
5. Push the same button pushed previously to close the door
6. Enjoy the movie
Jan 19, 2015 | iLO DVDR05 DVD Recorder
How do i play a dvd movie in ilo dvdr05 dvd recorder
You may have to connect to a different output until you can change the settings back.
Dec 03, 2014 | iLO DVDR05 DVD Recorder
Humming noise and vibration when steering left
bad cylinder, low fluid in your rack and pinion
Apr 26, 2012 | 1995 Pontiac Grand Am
Vibration at highway speeds loud humming noise,
Possibly a wheel bearing issue, does it `get progressively worse as speed increases or better as it decreases? does it stop when applying the brakes or get worse?
Oct 30, 2011 | 2006 Ford Escape
Our Samsung fridge srs757dw is making weird noises(it hums loudly). When the Freezer door is open it stops but as soon as it closes the noise begins again. What do you think is the problem?
Sometimes this can be due to vibrations within the duct , possible that the ventillating fan is frosted and so makes the noise with the door closed. So shut down fridge for few hours to defrost and check.Also make sure there are no loose screws or clips on the back panel and the evporator section that can cause vibration.
Aug 30, 2011 | Samsung Televison & Video
DVD drive
Over time the plastic gears wear and this is usually the reason for the vibration.This is not a indication that the drive is going its just wear and tear.You might want to replace after a while.
Good luck
Oct 12, 2009 | Toshiba Computers & Internet
Intermitent vibration noises when playing cds
This is normal for a Vibration to occur when playing CDS. You should not be alarmed with the vibration unless you hear a Scratching noise.
--P3NGYJ03
Mar 03, 2009 | Acer TravelMate 4202WLMi Notebook
ILO DVDR05 recorded DVD's freeze
Burn your DVDs at tow positions slower than what the system and discs say. It sounds as if there is a huge amount of error being introduced during the write process. Unfortunately, the old discs can only be recovered with an external program like Zero Assumption Recovery or the like....accordianman
Feb 28, 2008 | iLO DVDR05 DVD Recorder
Ilo dvd player
Did you find an answer for this? I have the same issue.
Jan 05, 2008 | iLO DVDR05 DVD Recorder
Dvd player turns on and that's it
I have ILO dvd ro5/zu Burner walmart cheapy and I read Capacitors for power supply go bad and leak there are 2 (fuhjyyu 2200uf 10volt) also it runs very very hot so I put in an old computer fan to cool it down works great now, problems with clock flashing and humming noise while recording and playing back. It still has a little hum but other than that it works great 3-4 years old over 150 dvd's burned.
Sep 29, 2007 | iLO DVDR05 DVD Recorder
iLO DVDR05 DVD Recorder Logo
333 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
