Question about Miele KFN8762SDED Bottom Freezer Refrigerator
Hoover fridge freezer VCN6185B Fridge section freezing up.
How to fit replacement temp probe.
  • 171 Answers
SOURCE: freezer is icing up and
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
  • 30 Answers
SOURCE: Freezing up
Primary Cause is Thermostate
Secondary Cause only Anti Freez Switch which is attached to the Evaporator Coil unit
Good Luck
Posted on Feb 16, 2009
SOURCE: Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Posted on Jan 18, 2010
  • 70 Answers
SOURCE: The fridge section of my Miele fridge/freezer
You require NTC for fridge evaporator. Part no.7323301. It is the one screwed to the back wall of the fridge with a green band on it.Behind the cover at the rear of the light.
Posted on May 24, 2010
  • 70 Answers
SOURCE: Miele KFN8462S fridge freezer is displaying an F2 fault code.
F2 Is fridge evaporator sensor faulty it will require new sensor part no.7323301
Posted on Jul 23, 2010
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
We have a Hoover No frost refrigerator/freezer. There is no control for the fridge temperature which is now running very cold (it freezes drinks, etc.). What can I do to increase the temperature of the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | Hoover HCA391FFK Bottom Freezer...
Fridge is freezing food
I have had the same issue with thick frost/ice at the back of my Fridge and almost called an engineer and considered replacing it.. BUT you don't want to so that: Do this:
1. Take freezer draws out and empty fridge so it is lighter and easier to move Fridge Freezer out
2. Chuck some warm soapy water down the drainage hole in back of fridge to ensure it is not blocked
3. Pull the plug. Leave it off for 5-10 mins.
4. Plug it in, reload her
5. Next morning.. perfect all back to normal
I think the unplugging just resets the thermostat and gets your machine back to life.
Jan 13, 2010 | Hoover Refrigerators
39 ltr engle fridge freezer wont shut off when at temp
hi,
the temp should be around 35-40 in the fresh side and below freezing in the freezer. If the probe is positioned wrong then it may not shut off. Does the probe need to be in the freezer compartment?If the freon level is wrong then the freezer may not get cold enough to shut down the control tstat. The low side pressure should be around 5 PSI.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
My performa refrigerator,on top,of unit is freezing all the food .where should the dial be set?
The fridge section shouldn't ever freeze anything.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 02, 2009 | Maytag Performa PAV2200
Fridge section freezes
I would need a model number to even try. Several different ones will probably work.
There are other reasons for the fridge to freeze. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Does the compressor ever cut off? How about when you turn the freezer temp control to the warmer side.
Aug 18, 2009 | Refrigerators
Fridge compartment is freezing in my Hoover upright fridge-freezer. Any advice greatfully recieved. Thanks, Owen
have you tried turning down the temperature for the freezer or fridge? The fridge gets its cold power from the freezer, it is siphoned into it. So turning down the freezer temp may help but a sensor may have gone bad in the motherboard of your freezer and not closing off the vent into your fridge
Dec 06, 2008 | Hoover HCA390FFK Bottom Freezer...
FRIDGE COMPARTMENT FREEZING
i had the same problem the sensor starts at the back of the pcb and snakes its way dow the back of the fridge into the freezer conpartment i ordered a new sensor thinking it was a temp sensor but turned out to be a defrost sensor compleat and utter hassel to fit due to the expanding foam i had to eventualy cut the block off that conects to the pcb and then reconecting it once i got the cable through the foam first 2 days seamed to work fine while there was nothing in it as soon as i put food in it again the fridge started to freeze everything again then about a week later it still ices up at the back the fridge but doesnt seam to freeze the food so much now so still unsure about it all
btw it was the exact same model and before i changed the sensor the light and the super light used to flash on and off
Dec 02, 2008 | Hoover HCA390FFK Bottom Freezer...
Hoover HCA300FK Frostfree fridge freezer
thermostat is not turning off.replace the thermostat
Aug 09, 2008 | Refrigerators
Miele KFN8762SDED Bottom Freezer Refrigerator Logo
Top Miele Refrigerators Experts
AJMAL KHAN
JonSnell Electronic
JonSnell Electronic
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
