Question about Sole Fitness Sole E35 Elliptical
Flywheel vibration There is a vibration coming from the flywheel enclosure while using the machine. The vibration increases as you increase the speed of your workout.
  • John Nock
    John Nock Dec 30, 2013
    We have cleaned and lubed all of the exposed rails and wheels per manufacturers recommendations. We have had and regularly used the machine for two years. The vibration problems started just recently.
Have Craftsman 6.75 lawn mower, briggs Stratton engine. How do I adjust running speed ??
Are you familiar with governor speed regulators on engines? There is a flap on a hinge under the flywheel cover which is moved by the air fins on the flywheel, which tries to close the throttle. There is also a spring that tries to open (increase) the throttle. So it's a contest between those two opposing forces! Increase the spring tension, and you will have more speed. But don't overdo it, or you could blow your engine! Good luck!
May 12, 2017 | Craftsman Garden
My Audi S3 2009 has had an increase in engine vibration and Revs by itself.
check the engine mounting for damages & transmission mounting.also check the mounting bolt for looseness and tight...
Nov 19, 2015 | Audi Cars & Trucks
Revs of the car go up but the speed doesn't increase at all,
The most obvious cause to this fault would be the clutch slipping then suddenly gripping and away it goes.Now are there any cluncking noises or is there any strong smell when this fault occurs.If there is a strong smell the chances are you will require a new clutch.If there is no smell it could be clutch release bearing,either way gearbox will have to come out.If there is any loud clunking noise,possible drive shaft,but this is unlikely. the problem needs to be diagnosed by a mechanic.Always ask for quotes 1st,If a clutch is required be prepaired for possible damaged flywheel.
Dec 11, 2013 | Cars & Trucks
Where is the starter located on 1985 Honda Civic?
The starter is located on the firewall side of the engine block, adjacent to the flywheel or torque converter housing. Early models, use a direct drive type starter, while the later models use a gear reduction starter. Otherwise, the two units are similar in operation and service. Both starters are 4-pole, series wound, DC units to which an outboard solenoid is mounted. When the ignition switch is turned to the start position, the solenoid armature is drawn in, engaging the starter pinion with the flywheel. When the starter pinion and flywheel are fully engaged, the solenoid armature closes the main contacts for the starter, causing the starter to crank the engine. When the engine starts, the increased speed of the flywheel causes the gear to overrun the starter clutch and rotor. The gear continues in full mesh until the ignition is switched from the start to the on position, interrupting the starter current. The shift lever spring then returns the gear to its neutral position.
Begin the starter removal by first disconnecting the wires leading to it
Hope helps (remember rated this).
Jul 14, 2010 | 1985 Honda Civic
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
The treadmill stop when i increase the speed and the error 26 show
Error 26 is what's known as a Motor Pulse Width Incorrect. It basically monitors the sensor signal and verifies that it's appropriate for the requested speed. If your machine uses an infrared sensor, check the line of sight between the optical eye and the sensor target, an array of black and silver wedges arranged like a pie. Ensure that it is 3/16" apart and that it's pointed at the larger point of the wedge section. Use an electronic cleaning compressed air cleaner to blow out any particles that could block it. Have a close look at the target, if it's torn or badly scratched, it will need to be replaced.
If the machine uses a hall effect sensor (magnetic) ensure the distance between the flywheel tooth and sensor is 3/16".
You can sometimes get this error if the speed sensor is faulty, but usually it will happen without you even touching the controls at that point because the lower board isn't receiving any signals from the sensor, or you will get a different error code.
May 21, 2010 | Precor 9.21 Treadmill
I have a Diamondback 1100 ES stepper which recently started operating incorrectly. It appears that the magnetic flywheel is not exerting any resistance no matter what setting I plug in. Initially when I...
I've had this problem years ago. If I remember, the flywheel pickup sensor on the left side of the flywheel is slightly misaligned. If you tweek it it should solve the problem.
Jun 06, 2009 | Exercise & Fitness
Vibration When Accelerating
Did you machine the flywheel? Because if you replace the clutch without machining the flywheel. The flywheel will have high and low spots on it. The new clutch is perfectly flat, and the old clutch was worn into the flywheel. Thus, vibration! I sincerely hope that I helped. Best wishes to ya.
Jan 26, 2009 | 1989 Ford Ranger
Sole Fitness Sole E35 Elliptical Logo
44 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Brett Duxbury
Brett Duxbury
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
