Question about Giant Brass 1
Suspension doensn' t work
Hi, After driving my new Giant brass1 first time in the forest the supsension was rigid. I tried every settings but it didn't worked
  • 24 Answers
The spring usually has a big knut at the bottom (or top) this controls the stiffness of the spring.
PS: leftie loosie, rightie tightie.
Posted on Dec 26, 2013
Creaking noise
I know, this can be extremely frustrating...
First and easiest, check that your rear wheel is tightened completely, this can also sound like suspension noises.
Next, a bit more effort, unscrew your pedals, clean out the gunk, put some grease on the thread and replace, tighten securely.
You might also have to check your wheel bearings, mine is in the shop at the moment because of this, bearing issues...
I would also check the BB (bottom bearing) where your crank goes through, before the last step. This can also cause a lot of noise.
Lastly, if it is your suspension, you will have to take it apart, every link and check every bearing, they so have a limited life, clean out all dust and grit that gathered inside, replace and grease all bearings and links, but don't over tighten the links.
Here is a full service manual for you:
https://www.giant-bicycles.com/_upload_it/bikes/models/manual/Anthem%20Service%20Manual.pdf
For a full suspension service, you will have to look at every single point that hinges on your frame, I count at least five on one side.
Hope this helps.
Dec 30, 2013 | Giant Anthem X2
Yz 125 04 stock supsension settings
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
yz125 stock suspension settings Yamaha 2 Stroke
2004 yz 125 5 speed
YAMAHA YZ125 Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jun 26, 2013 | 2004 Yamaha YZ 125
Hi, Tommy for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2004 yz 125 5 speed
2004 YZ 125 Suspension
Ford ka creaking on drivers side when driving over bumps in road or turning
Is this a suspension creak, or a door creak?
Components which you haven't had changed are:
bottom suspension arms
Anti roll bar links
Also lubricate your door lock mechanism, hinges and window rubbers as these can cause creaks from time to time.
Nov 13, 2012 | Cars & Trucks
03 forester xt pulling to one side crunching metal sound
Hi sounds like a wheel bearing or a suspension problem, either way it needs to be checked out by a mechanic as its quite dangerous
Apr 09, 2012 | 2003 Subaru Forester
It make a noise every time i hit a bump or drive in a bumpy road
It is possible that the fault can be due to the suspension or the dampers.
So you need to check all the suspension parts , check the action of the dampers to confirm this fault. Rigid suspension can cause this noise and it needs to be confirmed only after the parts is examined closely. Also you can check the strut and fittings, the steerring and also look out for loose ends.
Aug 27, 2011 | Cadillac DeVille Cars & Trucks
My psp was fast now slow
seems like your umd drive is not good, maybe could be mechanical hardware failure...try to clean and test with another umd disc...if doensn´t work try to buy and install a new one...
http://www.diytrade.com/china/4/products/3314368/PSP_2000_Slim_Laser_Lens_KHM-420BAA.html
Sep 11, 2009 | Sony PlayStation Portable (PSP) Console
I have a 2002 Audi All road Quarto with air supsension problem
i had the same problem with mine there is a bleed down solenoid on the side of the air pump this can stick and let the air the pump is pumping straight to the outlet i cleaned it and chacked the spring and it now works fine
Jun 29, 2009 | 2002 Audi allroad
Air supsension range rover 03
sorry havent worked on the newer ones with the air suspension.but i would imagine their is a height sensor on each wheel and this could be the fault.Worst case secenario is possibly having dealer to look at it sorry i cant help
Apr 21, 2009 | 2004 Land Rover Range Rover
Giant Brass 1 Logo
Top Giant Cycling Experts
John Egan
John Egan
Mark Schmit
Mark Schmit
dante
Are you a Giant Cycling Expert? Answer questions, earn points and help others
