Question about Tablets & eReaders
My charge light is flashing red and will not charge
When I plug in my device and try to turn it on the battery light glows red and a red light instead of a blue one will light up and I know I have charged the battery
at least you think you charged the battery . I would take it to a computer repair shop and have them check the battery
Oct 11, 2015 | Tablets & eReaders
When I attempt to charge using USB charger the charging light is red for a couple of seconds and then goes off. I have only just received this case/keyboard. It is obviously not already charged since the...
Turn the keyboard on and let it run all the way down. Then try charging again. If the Red light stays on, the keyboard has was charged. If the same conditions exist, then arrange for a replacement.
Mar 28, 2015 | Tablets & eReaders
When connected to charger red lights keeps flashing but tablet wont charge or switch on
Your dc socket is probably on its way out- soon it wont connect charge at all-bad future outlook on this- return if possible.
Mar 10, 2015 | Craig CMP741d Tablet
Screen has began to flash on and off and wont charge
I had a similar situation with my pipo s1. After further investigation I found that the jack the charger cord plugs into went bad. My charge light wouldn't stay on unless you held the charger plug in a particular position. The jack is hardwired into one of the circuit boards and to replace the circuit board was half the cost of the whole tablet. I junked it and bought a kindle fire. Better quality and longer lasting battery.
Dec 12, 2013 | shop-fun PiPO S1 7 inch Tablet PC Android...
Help pairing jbl charge
Put JBL Charge in pairing mode: turn on Charge. Hold down power button till it flashes red and blue. You're in pairing mode. Go to your device and find Charge and pair up. Done!
Jun 13, 2013 | JBL Tablets & eReaders
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
May 12, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Tablets & eReaders Logo
22 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
