Question about Caple Ovens
Twin ovens stopped working
Caple CR9220/1 both ovens stopped working. Have 5 hob rings working, one is not. All house fuses are fine
    Problem Solver:
  • 6 Answers
Hi, Have you altered the time clock on the cooker? It is possible that the clock/timer is set for 'Auto'
Posted on Dec 26, 2013
SOURCE: FAN OVEN NOT WORKING
power went off to the house now cant reset fan oven on hotpoint bs21
Posted on May 23, 2008
  • 16 Answers
SOURCE: Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Posted on Jun 01, 2009
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
barkencoa
  • 3463 Answers
SOURCE: oven has suddenly stopped working but the fan is
If the fan is working o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Posted on Oct 11, 2009
Testimonial: "many thanks for yur help"
barkencoa
  • 3463 Answers
SOURCE: Hob on my hotpoint oven trips my RCD
It is either a faulty ring, or the regulator that controls it is faulty.
You really need a meter to test the ring with to be certain which part is faulty.
Hope this helps.
Posted on Feb 21, 2010
Hello, I have a DTI704 that has recently stopped working after some electrical work in my house. After turning on the induction hob, the only buttons that seem to work are for the Top Left and Bottom...
call the technician for a proper diagnosis amn quote
unless the electrician doing the wiring altered the circuit to the unit , there will no connect for the fault
May 24, 2017 | Ovens
Do all neff oven & hobs have to wired in using 6mm cable or can they be wired into a13 amp system
If it is a single oven on it's own then it can be used from a 13 amp plug and socket, the same with the hob, if it is seperate from the oven it can be used from a 13 amp socket.
If it is a combined unit, then it will have to be hard wired to a seperate circuit using 6mm twin and earth cable, and fused on it's own circuit.
Nov 07, 2010 | Neff B1421 Electric Single Oven
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
Hope this helps.
Feb 21, 2010 | Ovens
My Delongi dsf905 oven stopped working
FIRST CHECK THE FUSE IN YOUR PLUG IF OK THEN IT MIGHT BE THE TERMOSTAT IS FAULTY CHECK THE ELEMENT IS NOT BURNT OUT IF SO REMOVE AND BRING TO A ELECTRIC AND PLUMMERS SUPPLY STORE FOR REPLACEMENT.
Nov 29, 2009 | Ovens
Ovens Logo
96 people viewed this question
Top Caple Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Caple Oven Expert? Answer questions, earn points and help others
