Question about Kitchen Ranges
Went bang tripped fuse now wont turn on
Removed element and still wont turn on still trips fuse have disconnected oven completely and fuse turns on ok element seems fine like new
    New Friend:
  • 24 Answers
Did you flip the switch in the switch box back on?
Posted on Dec 26, 2013
4 Suggested Answers
  • 1462 Answers
SOURCE: I have a Electrolux EXC643
circular element is almost certainly open circuit. often the breaker will trip when element goes faulty but not always. take rear cover off and check for continuity
Posted on Jul 08, 2008
  • 10865 Answers
SOURCE: blows house trip when oven is turned on
Here is a diagram showing how the range receptacle should be wired. I would begin by checking there.
http://www.make-my-own-house.com/electrical-wiring-diagrams.html
Posted on Apr 16, 2009
dmftrucker
  • 1922 Answers
SOURCE: Hygena oven trips main fuse box when switched on
sounds like that element is getting a "hot spot",high resistance area, will oven operate w/o that element in place?you also could have a bare wire touching the oven case somewhere, if it trips w/o having anything turned on remove back cover and examine all wires and connections
Posted on Aug 23, 2009
Hj4560 went off when out tripped electric wont turn on keeps tripping
Constant or repetitive disconnects are a sign of a serious fault. Wires can be OK, but elements can become stressed and burn out. If an element is energized and can no longer heat up, it shorts out and a circuit breaker may pop. Testing the elements with a VOM can indicate whether the properties are good or bad. Replace!
Feb 02, 2015 | Ovens
Grill stopped working
You need to disconnect the element and check for short to the body which can confirm that the power tripped due to this short.
If the element is intact and shows good reading then check on the switch and wiring harness , disconnecting the suspected wiring will confirm as there will not be any tripping.
Jan 23, 2013 | Neff Washing Machines
Hi My power box just tripped and my oven turned off, prior to this happening it was working fine. I have a smegg oven model se378mfx5. It now wont heat up, it turns on ok but wont allow me to set the...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 16, 2011 | Smeg Ovens
Using my EOB5630 oven went bang
the fan element will have shorted out. if you remove the panel from inside the oven you may see where the circular fan has shorted. It will have blown a fuse poss in a plug if connected that way.or tripped a circuit breaker. remember to set the clock when power is restored as it wont work until you do.
Jul 29, 2010 | Electrolux EOB5630 Ultrafan Electric...
I have a baumatic bc3510ss double oven. everything works fine except the large oven. you can turn on the grill or oven but when you turn on the temperature the rcb blows on the fuse box.
Tthere are a couple of possibilities for your prob, the thermostat, or the oven element is faulty.
Disconnect the oven element, and try it again, if it does not trip, replace the element, if it still trips, replace the stat.
Please rate my solution.
Thanks.
Nov 01, 2009 | Baumatic Ovens
Aug 14, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Thanks.
Feb 24, 2009 | Bosch HBL 5032 Electric Single Oven
Oven trips out when turned on
You will to check the fan oven element, it has probably failed.
Disconnect and try , if no fuse blow, then replace element.
Plz rate this solution.
Thanks.
Dec 14, 2008 | Ovens
Belling XOU252 Single Oven Trips Fuses Repeatedly
Hi.
Probably a faulty element, if you feel competent enough, disconnect the feed to the elements in turn, this should eliminate the problem.
Good luck.
Nov 20, 2008 | Belling XOU252 Electric Single Oven
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
