Question about Asko Washing Machines
Propeller pump propeller is broken on water pump
  • Asko Master
  • 5,323 Answers
HAVE TO REPLACE PUMP
Posted on Apr 03, 2015
9KG My machine fills up with water and does not drain, makes a noise but does not drain, what could be the problem?
does it go into wash cycle? if so then check for a clogged drain pump or pump with broken propeller/ if no wash cycle then check ur water pressure switch
Mar 06, 2015 | Washing Machines
Problem Hoover 200m 4.5kg top loading Machine not drain water
no drain? do u have a spin cycle working? If so check the water pump and hoses for clogged blockage. or broken obstructed propeller, can u turn it (pump) by hand?
Mar 02, 2015 | Hoover Washing Machines
CAN A MECHANICAL WATER PUMP BE BAD WITHOUT LEAKING OR ANY PLAY
Yes it can be, I have seen broken and rusted off blades on the propeller causing coolant circulation to be limited. The only way to check is to remove and inspect the water pump.
Jan 22, 2011 | GMC Sierra 2500HD Cars & Trucks
The pump is not pushing water through. Wat is the
ure the propeller and shaft turn, but I woulsd dare to say that they are actually turning independant of each other. Sort of like a stripped nut on a bolt. They both look like they are in place and working, but when you add any sort of pressure they just don work the way that they are supposed to. I bet the shaft is actually spinning inside of the propeller, as soon as the water pressure is built up, it fails. Spinning it with your fingers will not imitate the real life pressures exerted on the propeller and shaft, that the water pressure exerts under load (in operation). I would either rebuild it with new parts (new shaft and Propeller) or just go out and buy a new one with a warranty. There is no other reason why this pump will jnot throw water through your system... NO REASON, unless you have the thing hooked up wrong, but I think that would be impossible, wouldn't it?
Apr 24, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
Model ADP4552 AA class , the water is coming into the dishwasher but the "blades" aren't turning
Contrary to a lot of people's beliefs the spray blades are not hooked up to anything. The high water pressure pushed out through the tubes propel them like a jet and then they spin. So that is your motor most likely with a broken winding that is shorting and the unit not sucking or pumping water. The motor needs to be replaced to pump the water. The fill of the water is simply an electric valve.
Mar 17, 2010 | Whirlpool Dishwashers
Why is my dishwasher not cleaning the dishes even although the cleaning tablet is in the correct place
You may have blocked propellers you can unscrew the propellers and take them out to clean them eg while flushing them with water use a fine piece of wire to clean the jet holes .Failing that you may have broken or worn main pump impeller.Hope this helps. Kind Regards Stefan.
Jul 08, 2009 | Dishwashers
Dishwasher fills, when the pump is supposed to start it just whir
Hello, sounds like a broken wash impeller or a stripped drive impeller (the piece that fits inside the impeller). These two parts are driven by the wash motor and propell the water through the spray arms. good luck
Dec 27, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Bissell proheat self propelled series 7950 won't spray water and pump belt isn't broken.
I'm having the same issue and it was the pump. The metal drive gear sheared off of the plastic pump shaft. I JB Welded it back together, now I just need a schematic to reassemble the cleaner.
Sep 02, 2008 | Bissell 7950 ProHeat Upright Wet/Dry...
Dishwasher makes noise like grinding something during the initial fill of water as if it was trying to dislodge or somthing is getting in its way.
check your the pump's propeler as had thesame sound , first i thought needs capacitor but when i opended the pumu i find the broken propeler .
Apr 21, 2008 | Smeg 18 in. DWD409SS Built-in Dishwasher
Washing Machines Logo
24 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
