Question about Sanyo DS27930 27" TV
Video input nothing will seem to pop up on the screen when set to video1 or video2 im using these channels for ps3 nothing seems to happen tho. just a blue screen. any advice?
Require pin to acces on demand
Posted on Dec 26, 2013
4 Suggested Answers
  • 9 Answers
SOURCE: i have a standard sanyo tv i use for gaming. i
is it an onscreesn display that you want to remove? If you have the original remote press the display button and it will go away
Posted on Jun 10, 2009
  • 630 Answers
SOURCE: Just bought this set used and it's in Video2 mode
It may be auto selecting the input. Disconnect the Video 2 and see what happens
Posted on Jan 30, 2010
maatmartin7
  • 1212 Answers
SOURCE: Cannot get the tv into 'video1' (or ' video2') mode
Unfortunately you need the original remote. There is still a good chance you can find a Sanyo universal remote. Check your local Circuit city or Super K mart or Walmart and look inthe electronics sections. I have often seen the Sanyo universal remote! And yes it will have the options you are looking for. Good Luck!
Posted on Apr 20, 2010
NO PICTURE
Refer to the manual (free download here). Generally, a blue screen indicates a very low or non-existent signal. This can happen when the antenna is unable to gather enough of a signal from a particular broadcaster, or if an A/V input is selected, but the A/V device is not on or providing a signal. Since you are not seeing channel information when tuning, I suspect that the television is set to display an A/V input instead of the internal tuner.
With a working remote, locate the TV/AV button on the lower left (manual page 3 - item 8). When this button is pressed, you can choose to display signals on the ANT, VIDEO1, VIDEO2 or COMPONENT jacks. The ANT selection chooses the input on the RF jack such as an antenna or cable TV (with or without converter box). If using a cable box, the TV tuner should be set to Ch3 or Ch4 as determined by your cable box. Otherwise, select the VIDEO1, VIDEO2 or COMPONENT input that has the source signals you wish to watch from a cable box, DVD player, etc. that is connected to the rear input jacks. Page 7 of the manual details the connection and remote operation.
I hope this helps!
Apr 16, 2012 | Insignia NS- 27" TV27 TV
I cannot seems to get to the imput channels to play a dvd
on remote should be under video,,or input,,,on front of tv ,,i think input,,,or source,,it will come up 2 video1,,,video2 and so on
Nov 03, 2010 | Emerson EWF2703 27" TV
I cant seem to find the right channel to get my dvd player to work. Any channel suggestions?
You need to select either video1 (AV1), or Video2 (AV2) depend on which video input ports you are using to connect the cable to the DVD player.
Post back on how you have it hooked up.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 02, 2010 | Polaroid TLA-01901C 19 in. LCD TV
Wont sow anything on tv
make sure your cables are properly put in the correct input, also check the plug that goes into your ps3, if it still don't work see if you are putting the right video input on your tv i.e: Video1, Video2/ HDMI1,HDMI2, if problem still occurs maybe the A/V Cable is broken
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
WHY IS IT BLANK?
Make sure your video cable is hooked up properly to the TV. If it is and you still don't get video, then use a different known good cord. Also make sure you if your using an RF adaptor that you have it set on channel 3 or 4. If your using A/V cables that you have it set on the right video input, video1, video2, etc.
May 18, 2009 | Nintendo 64 Console
Unusable signal prompt on video input
be sure to cycle thru the input selections-- either w/Remote (input button), or channel +/- on the panel. my truflat 26" hd set has side/front/video1 video2 inputs, yours may have more or less. also, be sure you've plugged into an INPUT set, not an OUTPUT set. Does sound work otherwise on this set? If not, maybe interal speakers (menu setting) is set to off/not checked.
And on your PS3--goto the settings menu, sound outputs, make sure you select A/V connector and analog sound. The ps3 cable can become sloppy too, wiggle/check/reseat or try another cabe (usually video is touchy more than the sound though)
If you KNOW you've got the right input selected and the PS3 is setup properly, do you have another device with audio output to test on the TV? a notebook computer, walkman, cd player--anything that has rca outputs for sound--quick swap the cables to the new 'test' device-- if sound is OK with test device, either PS3 setting or cable is bad/wrong. if no sound from test device on TV either the tv is not using proper inputs, or is damaged, or the test device is not properly configured. If you have another input receiving device to test the ps3 output sound, like the LINE INPUT on a notebook computer, or a boombox with Aux inputs, test the PS3 sound output too.
Jun 08, 2008 | RCA TruFlat 27F520T 27" TV
Universal remotes
You have to use the input selection button. Example like video, video1 video2, aux etc...
Sep 01, 2007 | Symphonic ST419E TV
Can't get componet Video to work
Make sure you have an input Video signal on that Yamaha Reciever (exa. DVD, Cable box, etc...) then choose the right input selection on ur receiver (Video1, Video2, AUX, etc..), then connect ur TV on the receiver Monitor Video out. And put your TV on the right VIDEO input too (Video1, Video2, AUX, etc..). Goodluck
Aug 10, 2007 | Yamaha HTR-5930 Receiver
Sanyo DS27930 27" TV Logo
50 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
