Question about LG WD-80130F 7.2kg Washing machine
Mashine is not running - LG WD-80130F 7.2kg Washing machine
Saeco xelsis leaking water
The removable drip tray inside the front of the machine has two rubber inserts on the back side and the rubber has come away from the plastic causing a false leak. You will need to order a new one or fix the existing one.
Nov 26, 2013 | Coffee Makers & Espresso Machines
Delonghi EC850 coffe mashine red light are flashing
I have a Delonghi Figaro and the red led flashing means:
The unit has run enough times to likely be scaled, this is a reminder to run weak acid (vinegar or citric acid) through to descale. Then rinse twice with clean water.
Scale will slow the brewing process so if it's brewing slowly you should do this regardless of the LED.
The LED can be reset by pushing <Prog.> and <On.> at the same time.
Of course, none of this is in the manual.
Sep 14, 2012 | Coffee Makers & Espresso Machines
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
Asko W640 washing mashine !!! Got "engine failure" as an error message on the display and the mashine did not work. I changed the brushes and now the mashine is running until end of the...
You have to change the hose at the top of the drum and you need to polish the commutator in the motor - I removed the motor, took the brushes off, stuck the pulley in my lathe chuck, supported the motor housing and polished the commutator with a little 1200 wed and dry and some wd40 - seems to have fixed the exact same problem as yours.
Jul 25, 2011 | Washing Machines
I would like to know what is the problem with my washing mashine water is not flowing to mashine. Peaase advise
Hi, Are you having problem with both hot and cold water?
First make sure water source wasn't shut off. Remove the inlet hoses and see if the screens inside the valve are plugged.
Try moving the selector switch to see if water starts to flow.
If you put the washer into spin cycle, will it run?
Things to look for. Please let me know if I can assist you further in this problem.
Vic
Jun 13, 2009 | Washing Machines
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Programmes in washing mashine Eurotech FL 807 are really long (very old washer?) I want to run an empty mashine on 90 degrees (C) to clean it, can I combine hot water with a shorter programme although the...
yes - there is no thermostat to tell it the water is warm - go for it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 20, 2009 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
