Question about Vacuums
Babyliss bighair slow rotating
My babyliss bighair styling wand has started rotating really slow no obvious things stopping it moving need help thanks
3 Suggested Answers
  • 937 Answers
SOURCE: How do I fix a Babyliss "Big Hair" styling brush that won't rotate ( but the fan and heater work OK)?
Stan,
Take a look at this, may be helpful:
Posted on Jan 04, 2015
psrigley
  • 337 Answers
SOURCE: How do i fix the brush on my babyliss rotating hot air brush as it has stopped working after two goes..
you need to replace the drive belt look for screws on bottom and access plate left or right.
Posted on Jan 21, 2015
We have the Absolute Animal model. The brush does not rotate although there is suction via the wand. Is there a reset button somewhere. Thanks for any help you can offer.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 04, 2016 | Dyson Vacuums
Why did the beater bar stop working?
the problem may be either the hose or the spout[the area where connect the hose.Start the vacuum and twist the hose around especially near the end that connects to the wand.If it starts and stops it is probably the hose.....please get back to me if this doesn't help...Chris
Jun 04, 2015 | Electrolux Epic 6500 Vacuum
Jan 21, 2015 | Filter Vacuums
Belt not turning
Those have a tendency to short out in the wands. Use a test light or meter to find out where the power stops. Test lower wand first then upper then hose, then unit. Replacement wands are available, there's really no fixing them. I'll include a link to the wands I'm referring to.
Good Luck!
Lower (most common)
http://www.vacuummedic.com/product.php?id=452
Upper (very common)
http://www.vacuummedic.com/product.php?id=450
Feb 07, 2013 | Kenmore 25512/ 25513 Progressive Canister...
My beater bar doesn't work on my power nozzle
This could be caused by a few problems. I happened to notice a different repair that you posted about your Sidekick handheld power head also not working. Is this correct that you have two motorized attachments that don't work? If this is the case, this sounds like your electrical hose has gone bad, and has a short circuit somewhere inside of it.
You may verify this by using a simple Continuity Tester that you may pick up at any Hardware store. Simply place one of the testing prongs into the wire harness at the end of the hose that connects into the wand, and the other arm of the tester on one of the prongs that plugs into the wall. If the tester doesn't light up, move the one prong into the other electrical connection on the end of the hose that connects to the wand.
If neither one of these ports lights the tester up, then this indicates your hose has gone bad and needs to be replaced. Unfortunately there's really no way to repair the hose once it has a short circuit.
Here's a link to a replacement hose on our website that will work with your Electrolux Central Vacuum:
http://www.govacuum.com/elcevareho30.html
If you do have continuity in the hose, then try pushing the reset button on the power nozzle (small red pole on the right hand side). If you indeed however do have two different attachments that don't turn on, chances are most likely that your hose needs to be replaced.
I hope this was helpful to you in answering your question. If this helped, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by the Fixya community when an answer was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Electrolux Centralux Vacuum
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
Cannot remove attachment from proteam super quarter vac
Greetings, The ProTeam backpacks us a 1.5" hose and attachments. The way that the floor tool is removed is by unscrewing the collar of the attachment. Simply turn counter clockwise on the the part of the attachment that is secured to the wand and doesn't rotate. This should loosen the floor attachment, and you may then pull it off. The other floor attachment can be fitted, and then screwed on by rotating the opposite way, clockwise which will secure the attachment to the wand. I really hope that this information was helpful to you. If you ever need parts or supplies for your ProTeam, please be sure to check out GoVacuum dot com. If this was helpful to you, please rate the repair as helpful by clicking the 4 Thumbs up icons in the top part of the repair. Thank you very much, Chris J. GoVacuum
Mar 23, 2010 | Vacuums
Vacuums Logo
1,108 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
