Question about Hannstar I-Inc iF191DPB 19" LCD Monitor
Hannstar HN199DP Monitor power button just blinks on wont come on
  • ghostdog2003 May 17, 2009
    Hannstar HN199DP Monitor power button just blinks and Moniotor wont come on
I've noticed this problem as well with mine. I noticed it does it mainly when the unit is cold, like less than 70 degrees F. A quick fix is to warm the unit by whatever means you possess. If the blinking is rhythmic, that may be the unit trying to communicate a problem, so check your connections, change the cords, clean any dust from the ducts.
Posted on Oct 29, 2010
Monitor power button just flashes blue then yellow , does not work on other computer or other cable. Though it has to be solid yellow, It flashes even with no video cable. Thanks in advance for any...
If you have the power button "on" on the monitor and you unplug the vga cable from your monitor you should get a messege about the cable being unplugged. Sometime the inverter in the monitor can go out and you will be left with a very dim screen or no image at all. You can call up a local computer store and see if they can test the monitor for you. Taking the monitor into a repair shop will more then likely cost you more then a new monitor. I would check to see if the monitor is still under warranty or simply just replace it.
Best of luck..
Nov 18, 2010 | Hannstar I-Inc TW-191D Monitor
Monitor power would blink and not come on, and now the power light wont even come on. switched power cable, still no good. cant open this monitor either, what do i do?
Usually it's electrolytic capacitors' problem inside the monitor. In case you can use soldering tools you can handle it. Open the monitor's case and locate near the power supply socket the capacitors like these:
Replace ALL of them with new ones. The cost isn't too much and you can find them at any electronics components shop at your area.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 24, 2010 | Hannstar I-Inc iF191DPB 19" LCD Monitor
Monitor black but power light blink green
The 470uF 25 Volts capacitors on the power supply board are probably bad. Replace them all and tell us the result !
Feb 24, 2010 | Hannstar I-Inc TW-191D Monitor
I-Inc iF191D wont stay on
You have a blown power supply. If it is less than a year old its under warranty, send it in for repair. If it is out of warranty our site can show you how repair the internal power supply. Our site is :
www.ccl-la.com/badcaps.htm click on the link at the bottom for monitor repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 24, 2009 | Hannstar I-Inc iF191DPB 19" LCD Monitor
Same thing noise + no visual wtf
well u need to first check the power leeds for the monitor .......
if it okie then i think that u need to get in touch with the harware tech for the monitor and they will repair the things for you as they would open the monitor and manualy check the setting for the same
Jul 21, 2009 | Hannstar I-Inc TW-191D Monitor
Brightness and contrast light keep coming on
The up/down button on your flat panel is stuck. Please contact Hannstar Technical Support to have the monitor replaced if its still within warranty.
May 19, 2009 | Computers & Internet
Comp won't start
maybe there is something wrong with your power supply.. i think you need to change it
Mar 01, 2008 | Computers & Internet
Monitor lite blinks from blue to yellow
I bought my monitor last year and had it for only a couple of months and the same thing, it is blinking the yellow and blue led. I can't believe that so many people are having the same problem. I went to the I-INC web site and there is nothing posted about this problem. I think that they really need to address this and let the consumers know what is going on with this. I feel like just trashing this monitor. I ahd to end up buying a cheap bulky monitor to replace it.
Dec 27, 2007 | Hannstar I-Inc TW-191D Monitor
No access to DOS screen setup
Not exactly familiar with this particular monitor, but.. Once inside the computer BIOS (cmos screens), press either the external reset (autosync) button or from within the onscreen display. This should resize the screen (it does on any other model I've ever sold). Same solution for SAFE mode. Hannstar does not provide user support either by online or telephone. They rely on the distribution channel to provide support (namely, your reseller). The closest thing to direct HannStar support is here: http://www.hannstar.com/frontend_e/contact/MailProcessForm.jsp?type=10 ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Hannstar AH-191D Monitor
Open Questions:
Hannstar I-Inc iF191DPB  19" LCD Monitor Logo
576 people viewed this question
Top Hannstar Computers & Internet Experts
David Payne
David Payne
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
