Question about Baby Gear
Can I make my own electrical socket covers? - Baby Gear
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 5 Answers
You should definitely NOT make your own socket covers. It is better to leave them uncovered than to put an object into a live socket that is not intended to be there. The best thing to do is simply order them online or purchase them at any baby store.
Posted on Dec 26, 2013
How to repair a wall socket that has stopped working.
turn of breaker --remove wall plate screw ---remove socket disconnect wires ---reconnect --replace --cover and turn on breaker
How to Replace Standard Electrical Outlet For Dummies How To Replace An Old Electrical Outlet Wall Plug Replacement
Oct 10, 2016 | Electrical Supplies
Changing the headlights
Try not to touch the buld as you do the installation. There is a access cover in the back of the head lamp. This gives you access to the headlamp. Now when you get to the light buld and socket turn counterclockwise.Then the light bulb wil come out of its socket.From here disconnect the electrical connection.Now for the installation connect the electrical socket to the headlamp bulb.Install the buld in the socket,by rotating socket clockwise locking the retaining tabs to the housing,install cover test the light and you are done2_29_2012_7_31_02_am.gif
Feb 28, 2012 | 2004 Chevrolet TrailBlazer
I need help on how to change a headlight bulb on my 2000 toyota tundra
  • 1 Open the Tundra's hood and locate the back of the headlight assembly inside the engine compartment.
  • 2 Unplug the electrical connector from the assembly and remove the rubber cover from the bulb socket.
  • 3 Release the retaining spring to loosen the old bulb, and then pull it directly out of the socket. Carefully dispose of the bulb to prevent it from cracking or shattering.
  • 4 Align the tabs of the new bulb with the cutouts of the mounting hole. Then, carefully press the bulb into the socket until it's secure.
  • 5 Install the rubber cover in its original position and reattach the electrical connector to the headlight assembly. Make sure the rubber cover is fastened to the socket before continuing.
  • 6 Start your Tundra's engine and test the headlights to make sure they work before closing the hood.
Jul 30, 2011 | 2002 Toyota Tundra
How to change headlight lamp in 2005 Pontiac g6
To change the bulbs you need to first remove the 5 plastic pop screws on the front bumper. They're spread out at the top of the bumper right under the hood. Once you get those out, you have to remove the two hex bolts on each headlight. Then it gets tricky. You need to pull the light towards the front of the car until it pops out of the ball-bearing type mount on the fender. Once that pops out, you have to pull the front bumper forward while maneuvering the headlight out towards the front.
As per the manual it says as follows:---
Open the hood.
Hold the headlamp to prevent damage to the headlamp or to the fascia. Remove the bolts from the headlamp assembly. Remove the push-in-retainers across the front fascia. Remove the headlamp assembly. Lift the headlamp upward to release the locating tab from the front edge of the fender.
Disconnect the electrical connector from the headlamp assembly.
Remove the headlamp bulb access cover by rotating the headlamp bulb access cover counterclockwise, if necessary.
Remove the headlamp bulb from the housing by rotating the socket counterclockwise, if necessary.
Disconnect the headlamp bulb electrical connector, if necessary.
Remove the park/turn bulb access cover by rotating the cover counterclockwise, if necessary.
Remove the park/turn bulb from the housing by rotating the socket counterclockwise, if necessary.
Gently pull the park/turn bulb from the socket, if necessary. Install the park/turn bulb into the bulb socket.
Install the park/turn bulb socket into the headlamp housing by rotating the socket clockwise.
Install the park/turn bulb access cover by rotating the cover clockwise.
Connect the headlamp bulb to the headlamp electrical connector.
Install the headlamp bulb into the headlamp housing. Rotate the socket clockwise until locked.
Install the headlamp bulb access cover by rotating the cover clockwise.
Position the headlamp assembly to the vehicle. Lift the headlamp upward to release the locating tab to the front edge of the fender.
Install the bolts to the headlamp assembly. Tighten the bolts to 2 N·m (18 lb in).
Install the push-in-retainers across the front fascia.
Close the hood.
----------This will help.thanks.Helpmech.
Dec 25, 2010 | Pontiac G6 Cars & Trucks
How to put in a headlight on a 2003 Chevy Trailblazer
Please follow the stepwise solution carefully.
1.Open the hood and disconnect the truck's negative battery cable.
2.
Remove the grille. Unbolt and remove the plastic panel over the radiator, then use a flat screwdriver to release the clips securing the grille at the bottom to the headlight panel and lift the grill off.
3.
Pull up the retaining tabs for the headlight housing, which are on opposite ends, and carefully pull the housing out. Remove the park/turn signal bulb socket from the housing by detaching the holders and electrical connectors and disconnect the side marker socket.
4.
Take off the circular access cover from the rear of the headlight housing. Twist the bulb in a counterclockwise direction, withdraw the bulb with its electrical connector from the housing and disconnect the electrical connector.
5.
Hold the new bulb by the holder--do not touch the glass--as you connect the electrical connector. Place the bulb in the housing and twist it clockwise to lock it in place. Close the access cover.
6.
Install the headlight housing into the panel, connecting the electrical connectors, signal bulb socket and side marker socket. Push the retaining tabs in place.
7.Reinstall the grille and plastic radiator panel and reconnect the negative battery cable.
Problem solved.
Take care.
Aug 06, 2010 | 2003 Chevrolet TrailBlazer
How To Replace The Light Bulb In Micro Oven. Do I Just Take The Outer Cover Off ... Model Number: JE1590BC 001
Take The Outer Cover Off and you will find the bulb socket in the aproch of magnetron, you must unscrew a single screw to take of the socket. befor that operation disconect your oven from the electrical suply and do not touch anything else. clamp well the cover and do not forgot something in the oven (under the outer cover.
Feb 21, 2010 | Kitchen Appliances - Others
How to change lowbeam headlight bulb on 02 chev trailblazer
  1. Open and support the hood.
  2. Remove the grille.
  3. Pull up on the retaining tabs in order to remove the headlamp assembly from the headlamp panel.
  4. Disconnect the headlamp leveling electrical connector from the motor/actuator if equipped.
  5. Disconnect the headlamp electrical connector from the headlamp assembly.
  6. Remove the side marker socket from the headlamp assembly.
  7. Remove the park/turn socket from the headlamp assembly.
  8. Remove the headlamp assembly from the headlamp panel.
  9. Remove the access cover from the rear of the headlamp.
  10. Disconnect the electrical connector from the socket.
  11. Rotate the bulb and socket counter clockwise in order to remove the bulb and socket from the housing.
  12. Disconnect the electrical connector from the socket.
  13. Remove the bulb and socket from the headlamp.
Replace the low beam bulb with another low beam bulb. The low beam bulb has a gray tip and a grey socket.
Oct 17, 2009 | Chevrolet TrailBlazer Cars & Trucks
How to change front headlamp bulb? Low beam
  1. Open the hood.
  2. Remove Grille.
  3. Remove the 2 retainers on back of headlamp assembly and remove the headlamp from the sheet metal panel.
  4. Remove the access cover from the rear of the headlamp.
  5. Disconnect the electrical connector from the socket.
  6. Rotate the bulb and socket counter clockwise in order to remove the bulb and socket from the housing.
  7. Disconnect the electrical connector from the socket.
  8. Remove the bulb and socket from the headlamp.
Installation Procedure Important: • Replace a high beam bulb with another high beam bulb. The high beam bulb has a black socket. • Replace a low beam bulb with another low beam bulb. The low beam bulb has a gray tip and a grey socket.
Oct 14, 2009 | 2002 Chevrolet TrailBlazer
How to change the oven light bulb in a candy f245. Glass cover on inside doesn't seem to undo - moves a bit each way. No apparent access from outside.
The glass cover does come off. Use some latex gloves or non skid material and grasp the lens firmly and turn counter clockwise.
Jul 15, 2009 | KitchenAid KEHC309 Electric Double Oven
How do I replace a taillight lens on a 1991 Geo Storm?
Rear Turn Signal, Brake and Parking Lights
STORM COUPE
  1. Disconnect the negative battery cable.
  2. Lift the luggage compartment floor carpet toward the front of the vehicle and remove the spare tire cover panel.
  3. Remove the ten plastic retaining clips from the rear end trim panel.
  4. Disconnect the luggage compartment lamp electrical connector.
  5. Remove the luggage compartment trim panel and the rear end trim panel.
  6. Disconnect the rear combination lamp assembly electrical connector. Fig. 1: Rear Turn Signal, Brake and Parking Lights — Storm
  1. Remove the seven nuts and the rear combination lamp assembly from the vehicle.
  2. Disconnect the rear combination lamp electrical connector.
  3. Remove the four bulb sockets from the rear combination lamp assembly and remove the four bulbs from the sockets. To install:
  4. Install the four bulbs to the sockets and install the four bulb sockets to the rear combination lamp assembly.
  5. Connect the rear combination lamp electrical connector.
  6. Install the rear combination lamp assembly to the vehicle and the seven nuts.
  7. Connect the rear combination lamp assembly electrical connector.
  8. Install the rear end trim panel and the luggage compartment trim panel.
  9. Connect the luggage compartment lamp electrical connector.
  10. Install the ten plastic retaining clips to the rear end trim panel.
  11. Install the spare tire cover panel and the luggage compartment floor carpet.
  12. Connect the negative battery cable.
Mar 21, 2009 | 1991 Geo Storm
Baby Gear Logo
317 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
