Hi, I have a problem with my k52jc, at startup and lately even when shuting down, the graphics go crazy. The screen gets white, blue and green sometimes even b&w and it's like swirling colours and it has a dropping line that clears or restores. I have no clue what happens. I recently reinstalled Windows 7-x86, but I got the same system before and it was working fine. Anyone with this problem, or a solution?
    Top Expert:
  • Computers & ... Master
  • 22,195 Answers
I am guessing here. Is it Asus?
Try an external monitor to rule out the laptops screen. If the issue occurs on both screens, I think you have a GPU issue.
Posted on Dec 26, 2013
  • Cristina Vrinceanu
    Cristina Vrinceanu Dec 27, 2013
    Thank you, I've tried and it goes well on other screens. Still have no clue...
  • JonSnell Electronic
    JonSnell Electronic Dec 27, 2013
    In that case look on ebay for a replacement screen. Fitting is not too complicated, if you go to utube, search for your model number and add screen replacement there are lots of video tips on how to replace your screen.
Rubec
  • 42 Answers
SOURCE: Bootup problem
Your CPU is overheating.
Try and get into the BIOS and increase the fan speed & any aother fan on the system. Don't increase the temperature range, as this will damage the system.
You won't be able to sort out the software problem until the system is running within the hardware limits.
You can also run a office fan to help get the system to cool while making the changes in the BIOS.
Posted on May 11, 2008
mewms_14904
  • 1027 Answers
SOURCE: evesham voyager 8615 gtk
Easiest way is to run eversesthome
click on + by motherboard, click on chipset, click on northbridge at top of right column,
This will id the chipset to google updates.
Posted on Apr 14, 2008
  • 150 Answers
SOURCE: Touchpad no longer working
go to control panel and click on devices. click mice and see if it has been disabled.
Posted on Feb 28, 2009
  • 788 Answers
SOURCE: I get a blue screen with flickering white lines
It couuld be the invertor is burning out.
If you boot into safe mode and the same thing happens, it is not a software problem or drivers.
Posted on Sep 28, 2009
  • 479 Answers
SOURCE: My Acer 4730Z laptop screen went haywire
If the ACER logo is also fuzzy this is the problem of display panel cable or display panel itself.
Thanks
Posted on Dec 09, 2009
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
Screen is going crazy
Okay, it could be two things, 1.) Your graphics card is either overheated or going out. 2.) it's possible you have a messed up display screen. I'd try looking at your computer display settings and see if you can calibrate the color on your screen to see if it helps or not.
Jun 05, 2012 | ASUS K52F Notebook
I have hooked up all cables correctly however when i attampt to record of my xbox i get black and white record screen ive tried 3 diffrent record program im using the HD componet cable (blue green and...
Greets - You are mixing cables up. You need to connect the Dazzle yellow, red, white cables to the yellow, red white cables on the TV. You can't plug standard video/audio cables into the component (red, blue, green) connectors on the TV.
take a look at this diagram, just pretend the devices on the left are all connectors on your TV.
http://www.pinnaclesys.com/presskits/Dazzle/DazzleDVD_Recorder_ReviewersGuide_May06.pdf
Good Luck, Mikeywaf
Mar 03, 2011 | Pinnacle Dazzle DVD Recorder
Asus k52jc graphic card problems when i play pro evolation soccer 2011
hi this problem because your card graphique it s not power to let you play this game,or because you haven a enough memory.
Feb 23, 2011 | ASUS K52jc-b1 15.6" Notebook - Core I5...
I've installed GVRX26P512H on my pc. i used vista sp1
i would uninstall the card as blue screen errors are extremely bad for your computer if you get enuf of them your computer will basically die, or take it to a computer tech and have it fixed properly
Aug 17, 2009 | Gigabyte GV-RX26P512H RADEON HD 2600Pro...
White as pink, black as green
boot up your laptop and take a magnet in your hand and revolve around the screen the screen might go crazy but all the colors will be back in a while. :)
Mar 23, 2009 | Fujitsu AMILO PC Laptops
How to master clear the handphone 9502 beside
Sorry for having read your post that late. I think you have already sorted it out by now. Anyway, in order to hard reset the 9502 by hardware means, press and hold both the blue Fn and the green phone buttons, and, at the same time, press the reset pin with the stylus pen. A white screen will come up asking for confirmation. Just confirm it (with the left softkey, if I'm not mistaken).
Hope it works for you.
Cheers!
Carlos
Mar 10, 2009 | i-mate Ultimate 9502 Cell Phone
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
Laptop screen has been invaded by green and red/purple germlins
haveyou tried shutting it down and restarting it? it may just be the screen going bad
Jan 26, 2009 | JVC AV-48WP30 48" Rear Projection...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
