Hi i'm rajesh(tec)...25fn1dx sharp tv vertical ic missing pls tel me that ic no:
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Hi Rahesh
You claims to be a technician. Don't you have any service manual with you to proceed? What type of tech:!! You're? keep all technical manual of your own, and try to do work. Who the hell taught you to do service work without any service manuals? Can you point out him/her to me?
google.com/+GopakumarGopalan
Posted on Dec 26, 2013
  • 1 more comment
  • The Knight
    The Knight Dec 26, 2013
    http://electronicshelponline.blogspot.co...
  • The Knight
    google.com/+gopakumargopalan
  • The Knight
    Fixya is an open forum to help others to rectify the problem to their devices. Not meant to make anyone a revenue out of it. OK?
MikeNJ1964
  • 398 Answers
SOURCE: tv cuts off 10 seconds after switch on and destroying vertical output ic
If the main IC is not putting out a vertical drive signal then the vertical output will not do anything and therefore will not be damaged. What exactly do you mean by the set "literally eats deflection IC's"? What is the number on the vertical output IC? I will bet that your pump-up cap or pump-up diode is defective.
Posted on Jul 05, 2007
  • 556 Answers
SOURCE: missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Posted on Sep 23, 2007
Vrya
  • 62 Answers
SOURCE: Kv-36xbr800
Hiii...
My version is :
For safety reason you should replaced them ( Horizontal ic,Vertical ic, Deflection ic) and olso all the big capasitor nearest the ic....that's my version....if you have big budget for it....he..he....
Thank's
[Vrya]
Posted on Feb 19, 2008
  • 4234 Answers
SOURCE: how to locate vertical output ic on mainboard
This should be a small flat IC attached to a heatsink and will be marked TA8427. I think this one has about 11 pins in it.
Dan
Posted on Jan 26, 2009
Bat1956
  • 585 Answers
SOURCE: tv repair
A vertical line means the line is up and down in the middle of the screen. That would indicate that the vertical IC and the surrounding components are working perfectly. A vertical line as described is the result of a lack of horizontal deflection (to move the beam from side to side) Since the high voltage is obviously OK, the problem is most likely a bad solder connection in the horizontal yoke circuit. Examine the bottom of the PC board in the area of the flyback transformer, and yoke connector (has four wires Red, Blue, Green, Yellow).and the pincousion coils, capacitors, etc in between. Flexing the board in that area may cause the problem to come and go. Resulting arcing should also be visible. BE CAREFUL, as hazardous voltages are present in the circuit!
Posted on Nov 29, 2009
No vertical output
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 17, 2014 | Televison & Video
Only a horizontal line can I see in my TV
In most cases the vertical output IC and possibly a fusible resistor off of the high voltage transformer are bad. The vertical output IC is located on a heat sink and usually right next to the vertical yoke winding connectors that are green and yellow in most sets. Please take a moment to rate my answer..Thanks...
Nov 24, 2009 | Sharp 27G-S60 TV
Turns on but quickly turns off
hi
you have defective power oscillations! in this model you have to replace the vertical output ic. because the power oscillation for Jungle IC is passing by from Vertical output.
Thanks!
Dec 29, 2008 | Sharp 32U-S60 32" TV
Tv cannot display only a line in the screen
for short circuit it will show  like this if no short circuit
i think ur tv display tube has dead if it is in warenty pls exchange the tv
Jul 31, 2008 | Sharp 25R-S100 25" TV
Sharp Tv 25E-M50
WELL FIRST U HAVE TO SEE WHETEHR THE SUPPLY FOR VERTICAL SECTION IS OK.IF ITS OK THAN.CHECK FOR SOME DRY SOLDER AT VERTICAL SECTION.OR ANY LEAKAGE CONDENSER ,AT LAST REAPLACE THE IC VERTICAL.IT WILL BE OK'
May 21, 2008 | Sharp 25N-M100 25" TV
Sony tv no picture only horizontal line
The probable defective part is the vertical IC. If changing that does not resolve the problem, check the capacitors in the same circuit. Also, check for the proper voltages at the vertical IC. If the IC is not being fed its power, it won't work either. I don't have a listing for your specific model. If you can post the vertical IC part number (LA7837 for example), I can list the voltages per pin.
Dan
Apr 09, 2008 | Televison & Video
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Sharp 25" tv unknown model (no av in)
It is a simple trouble, tv has got dry solder joints in the vertical deflection circuit. Resolder vertical output ic pins and related components, this will be okay.
Dec 17, 2007 | Sharp 25R-S100 25" TV
Tv cuts off 10 seconds after switch on and destroying vertical output ic
Jul 03, 2007 | Sharp 27K-S100 TV
Re:tv
Hi Redd, You might have better luck posting this under Sharp TVs: http://www.fixya.com/support/sharp/standard_televisions The black lines at the top of the screen are usually an indication of a problem with the vertical output section. It's often bad electrolytic capacitors, the vertical IC, or both. That's apparently not a US model, so it will be hard to find the values but you could contact Sharp Philippines: SHARP (PHILS.) CORPORATION [Philippines] Km.23 West Service Road, South Superhighway, Alabang, Muntinlupa,Metro Manila, Philippines Tel: 63-2-842-1371 Fax: 63-2-842-0530 Service Center Tel: 63-2-807-4991/4992 Fax: 63-2-807-0388 Home Page: http://www.sharp.ph/ Good luck.
Dec 19, 2006 | Sharp R-930AK Convection/Microwave Oven
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
