Question about Water Heaters
No hot water and no heating
How to reset it
  • Water Heaters Master
  • 5,245 Answers
Unit stiebel Tempra 24Hot water is running through house but cold water pipe is getting hot. Hot water pipe is not getting hot. When cold water connection is removed and water is turned on hot water is...
follow this steps and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel 585dc480-4881-44a8-afda-7267c0f3de26.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 02, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
No hot water
1) Electric water heater? Push reset button. Check if tank has hot water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
2) March 2013. Add a comment and say what type, brand heat you have
Mar 07, 2013 | Water Heaters
Sime super 80.. Heating and hot water at the same time?
going off on a safety possible high temp unit needs service such a nozzle filter if oil or thermocouple if gas
Jun 16, 2017 | Water Heaters
Recently purchassed system from you plumber installed it and we asked specifically not to set it on child settings.....we have not had one HOT shower since. how do we go about resetting the hot water...
These Tankless water heaters attempt to heat water as it quickly travels through a short series of heated copper pipes. A high volume of water at an accelerated speed has little time to heat up as it passes through its heating source. You can turn up the temperature (which you undoubtably tried) and turn the water volume all the way down. These settings will produce the hottest temperature capable of the unit - given the entry temperature of your water source.
Most underground water enters at app 52 degrees - and becomes even colder due to ambient temperatures. Difficult to raise this temperature 60-70 degrees in a few seconds of heating.
I've routed a series of copper pipes adjesent to the home heating system in an attempt to pre-heat incomming water. It's only a few degrees warmer, but results a 20- 30 degree hotter delivery.
I have installed some top end units that simply delivers Hot water without compermise.
Mar 01, 2011 | Bosch & Tankless LP Hot Water Heater
I have a Reliance 501 model # 5 30 2srs4. I had to reset the unit after waking up to cold water. The water heated up in no time at all but the water was super hot. So hot it triped the reset button again....
No, the top thermostat will always heat first and then it should dwitch the power to the bottom one after the top of the tank heats...this is to get you hot water faster...
The top thermostat is bad and is not shutting off or switching....
Replace the top thermostat/reset combination and you''l be good!!
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 03, 2011 | Reliance & Lowboy& Electric Water Heater
I have a reliance 606 electric water heater. This is my problem. The water gets unbearably hot then I have to reset the reset button on the water heater. I am thinking that I need to replace the heating...
you need to replace the thermostats. the elements are working, as your water is getting hot.
I would replace both upper and lower thermostats. be sure to set the temps the same for both.
the thermostats sit against the tank and read the tank temperature. if one is malfunctioning, they will over heat the water, causing you to get severe hot water.
also as a precaution, I would replace the temperature and pressure relief valve. if your water is getting that hot, and this has not "popped" then it is time to replace it.
Sep 06, 2010 | RELIANCE ELECTRIC WATER HEATER
Water heats for about 3 seconds and goes cold
Take the cover off and look for reset that has trip.If you can't find no reset turn the power off and wait for five minutes,turn on and turn water on also to see if you get hot water.
Mar 14, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Water Heaters Logo
15 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
