Canon mp270 Hi, I have an error code p09, after following the steps to get into the service menu no green led lights wil apear only alterating green and amber? Is there an other way to reset the eprom?
arunkorani
  • 32 Answers
SOURCE: Error 6A00 and my printer not printing
have you tried with new cartridge, assuming cartridge doesn't have problem== Open front plane of the printer on the left hand side you will see the white strip which is causing assy to stuck.. try it arun
Posted on Jul 21, 2007
kev1952
  • 26 Answers
SOURCE: Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Posted on Sep 19, 2009
pineworks
  • 4041 Answers
SOURCE: Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Posted on Jan 25, 2010
SOURCE: canon printer mp270 with error code 5200 ( ink
Often it can be caused by dirty contacts on the print head, so clean them with contact cleaner or methylated spirits this may just fix your problem, try that before you do anything else If not that, then it may be Over heating or Under heating of the print head assembly, according to manufacturer.... replace head assembly...
Posted on Nov 08, 2010
  • 270 Answers
SOURCE: My Canon MX310 has an error code U051. I have
Error Message: Check Ink U051
This message appears when the cartridge not installed, not properly installed, or non supported cartridge is installed.
As a result the printer cannot recognized the installed cartridge.
Remedial action:
* Reinstall the cartridge properly
* Ensure that you installed supported cartridge only
* Replace the cartridge
Posted on Nov 18, 2010
What is 6801 error?
6800/6801/P09 - Orange and green light blinking 9 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
From: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#6800
Feb 16, 2016 | Canon PIXMA Office Equipment & Supplies
Tip
How to reset waste ink counter of canon ip 4000?
the procedure to reset waste ink counter of canon ip 4000 printer is as follows,read it carefully step by step:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons.
The LED lights in green to indicate that a function is selectable.) .
2) While holding the Power button, release the Resume/Cancel button. (DO NOT
release the Power button.) .
3) While holding the Power button, press the Resume/Cancel button 2 times, and
then release both the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in
orange and green, starting with orange.) .
4) When the LED lights in green, press the Resume/Cancel button 4 times. (Each
alternately in orange and green, starting with orange.) .
5) Press the Power button. The LED lights in green, and the reset is performed.
(When the operation completes, the printer returns to the
menu selection mode automatically.) .
6) Press the power button to exit service mode.
Note:- if you accidentally press the Resume/Cancel button more than 4 times in
step 4 then just press the Resume/Cancel button at least 10
times and the printer will be returned to step 4 automatically.
BTW the other functions that are available at step 4 are -
press 0 times = power off
press 1 time = Service Test Print
press 2 times = EEPROM information print
press 3 times = EEPROM initialisation
press 5 times = Destination settings (country information, do not play with
this)
press 6 times = Printhead Deep Cleaning
press 7,8 or 9 times = not used in servicing so do not play with these.
press 10 times or more = return to menu (step 4) .
This will help.thanks.
on Mar 10, 2010 | Office Equipment & Supplies
My canon inkjet printer mp276 error blinking 07P
Causes : Error P07 shows you printer ink abosorber is almost full. Solution : Here is your answer to fix your error. So you need to follow the instruction step by step...
Step 1: Entering Service Mode
* While the printer is OFF, press and hold the Start/Stop button (Resume/Cancel in some other models). * While holding the Start/Stop button, press and hold the POWER button. * When the POWER LED (green light) lit, release the Start/Stop button (still holding the POWER button). * Press the Start/Stop button TWICE (still holding the POWER button) * Release the POWER button. * Wait for the LCD to display "0? (zero).
Step 2: Using Resetter / Software Download Ressetter ; http://www.ziddu.com/download/10241255/ServiceTool_1050.zip.html
* Run "service_tool 1050.exe". * Confirm detected USB-port numbers on USB port column. * Click "Main button" on Clear ink counter section. Make sure there are papers in the paper feed because the printer will print after the process is complete. * Click "platen button" on the "Clear ink counter" section. The printer will print again. * Turn off the printer and then turn the printer on. You printer is ready for use.
Sep 01, 2011 | Canon MP270 All-In-One InkJet Printer
My printer is coming up with the error code 3 which is flashing. can you help please
Clear error codes
First make sure that there isn't anything keeping the carriage from moving freely.
Then follow the instructions below:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
The number of the Reset
button pressing
LED Codes:-
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jul 22, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Error Code no. E000067-0110
Resetting Ink-Waste Overflow Counter Canon Pixma iP3000, iP4000, iP5000 Printers
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
  2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
  6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
If the issue still persist contact manufacturer
Jul 06, 2011 | Canon iRC3100 Printer
MY MP160 FLASHES E AND # 3 ALTERNATELY
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
button pressing
LED Function Remarks
procedures below.
procedures below.
Aug 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E 4, 2 canon pixma mp 160
E42 means scanner error. May require a hard reset(disconnect from power supply for 30 min). Otherwise may require factory reset procedure to be applied. Follow the steps below:
Mp160 Reset Counter
Service mode operation procedures -
press the Power button while pressing and holding the Stop/ Reset button.
the printer will move into a service mode. (Waiting for menu selection)
according to the function listed in the table below.
The number of the Reset button pressing LED Function Remarks
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
Jun 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp150
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
MP150 Error code 4 and 5
Don't use refill cartridges, because it will damage your printer someday. and will cost your parts as brand new. so better use the original ink.
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Oct 24, 2007 | Canon PIXMA MP150 All-In-One InkJet...
CANON PIXMA MP150
Error E/2/7 Solution=waste ink basket
Mp150
Reset Counter
button pressing
procedures below.
procedures below.
Sep 03, 2007 | Canon PIXMA MP150 All-In-One InkJet...
jasbo
jasbo
