Question about Thomson WHP3001 Wireless Headphones - black 2 phono plugs - 3.5
Wireless head phones statice static sound interference
When connected i can just about hear but lots of static interference sound could this be caused by wi fi,also when headphone plug is put in to tv the sound is not muted
How do I get rid of the static sound in my 4PR908?
There causes varies from types of headset to another. In respect of a wireless headset, the static sound is caused by interference. Whereas in a cord headset, a loose wire somewhere in your headset or cord is responsible for the static sound or crackle. It might also emanate from the mic in respect of a one calling, or from the ear-piece.
The solution with a wireless headset is to move away from any device e.g computer which might have cause the static sound. Resetting the wireless headset is also a solution measure.
In the case of a cord headset; Get the cord wiggled at the plug and at the headset; and then move the mic to locate the loose connection. Where the problem occurs, loop the wire, taping it down at the point. soldering the affected wire is best than taping.
Finally, if the static sound persist;which it should not after all the treatments; check on the volume of the device. Reduction of the device volume can go a long way to bringing the longed solution. Similar problem occured with my headset;and was solved via the same recommended possibility.
Jan 30, 2015 | Wireless Gear 4PR908 Bluetooth v2.0 EDR...
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
Television sound is static y
This status could be caused by the volume limiter inside the unit thus causing static, thus you will need to have it repaired. The cost of this repair ranges from $50-$90 bucks depending on the actul cost of the part causing the interference,
Thanks and please do be considerate while your are passing threw fixya today to leave postive feedback for those who have helped you today.
May 26, 2010 | Emerson EWF2004 20" TV
Very bad stati on ge cordless phone
Often static is caused by RF or EM interference. The interference may be getting into the system though the power or telephone signal cable being near many other cables, or because the unit is situated next to a strong source of RF or EM field.
I recommend changing the location of your cordless phone, away from such noisy sources (microwave, router, DC charging adapters, computers, etc). Try the phone in an outlet that has nothing else on the circuit, if possible.
I hope that helps.
May 02, 2010 | Uniden Cordless Phone
I have a Uniden set of of phones - 5.8 GHZ. Both are making a loud static sound when you turn it on. We can hardly hear. We unplugged both sets for a while, but this did not get rid of the static sound.
• Keep the handset away from microwave ovens, computers, remote control toys, wireless microphones, alarm systems, intercoms, room monitors,fluorescent lights, and electrical appliances.
• Move to another location or turn of f the source of interference.
Dec 31, 2009 | Uniden 5.8GHz Cordless Phone
Static from a wireless (plugs into the wall)intercom
There are a few possibilities that could be the cause. The fact that its only one unit malfunctioning most likely means it is some type of fault in the unit it self and not the connection. Have you swapped it with another unit to make sure its the unit itself? If so try these. The first and most simple is the easiest to fix. It may sound odd but dirt and other contaminants can cause a great deal of interference "static" when they get worked into the metal connectors that carry signals. If that is the case, I recommend that you unplug the device and use "electronics" contact cleaner on all the connectors and if possible the metal contacts themselves. If it is not a containment then it could be a loose connector blown speaker/mic or even a solder joint inside the device. If that is the case you may have to have it repaired.
Hope this helps.
Apr 20, 2009 | Southwestern Bell Lands Phones
Static in my panasonic telephones
A possible cause for the static in your cordless phones could be dimmer switches around the area of your phone that causes static. Turn the switches completely off (not just turned down) and see if the static leaves. You can replace the dimmers with regular switches if that clears your static. If it does not, another trace for interference: you will have to take a portable radio and turn it to AM 550 mHz and tune it to the loudest crackling noise. Carry the radio around looking for the loudest static interference. Could be a loose connection in a receptacle or panel box. Any small malfunction can cause static on wireless devices.
Nov 21, 2008 | Panasonic KX-TG1033S Cordless Phone
GE Dect 6.0 Cordless - Loud Static
question is are you running a pc and router/ modem on the same land line
if so you will need the line filters to the phone base
the computer data is transferred by the same land line and there is every possibility that the different frequencies is what is causing the static
reference from a uniden trouble shooter ( will be common as the phones use the same medium)
lots of noise or static on the line === possible solutions --check for interference from appliances ( microwave , tv etc ) or wireless devices ( baby monitors wifi equipment etc)
move the handset base away from the source
if you have any device that uses the phone line , add a DSL or telephone line filter to the system
it is possible from the times you state that the interference could be coming form a neighbour or further down the line so the filter may be the option
available from phone shops or places like JAYCAR
Jul 11, 2017 | Uniden Cordless Phone
Thomson WHP3001 Wireless Headphones - black 2 phono plugs - 3.5 Logo
48 people viewed this question
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
