Question about Yamaha Audio Players & Recorders
YAMAHA RX-A830. No sound on central channel
Hi, I have a brand new YAMAHA RX-A830 but I have a problem. No sound at all on the central channel even in the setup menu with test tone. All other channels OK. I already made a lot of test. - Changing speaker. No luck! - Try every sound mode. No luck! - Reflash firmware. No luck! - Testing preout. Yes! I have all channels ok on preout jacks! So, I presume that it's an hardware problem on the power amplifier of the central channel. Any idea? Any advise? By the way, I got the schematics and I'm a not so bad technician. Sincerly, Mike
    Master:
  • 238 Answers
Hello Mike!
Check the receiver settings
Posted on May 03, 2017
  • 151 Answers
SOURCE: Yamaha RX-V800 - No audio on left and right channels
make sure the (a) speakers are switched on,this may be a switch on the front panel or in the main set up menu.
hope this helps.
cable guy.
Posted on Jun 04, 2008
  • 336 Answers
SOURCE: Surround speakers work in test mode but won't come on during play
Check that you set it to Pro logic and check the speaker set-up. Set it to 5.1 Sounds like somthing is in the wrong setting.
Posted on Jan 12, 2009
jamo297
  • 19 Answers
SOURCE: RX-V1600 when i turn on no sound or channels display on
If you are sure that the speaker wiring is correct and connections are good, then:
  • Check the input and output connections are correct for each source.
  • Check that the input mode is not set to DTS or Analog - rotate the input selector to the source and the press the input mode, set it to Auto.
  • Also check that the front speakers to be used are selected A or B (or A+B).
  • If there is an optimiser microphone supplied with this receiver, ensure that it is not still plugged in.
Hope one of these solutions work for you.
Posted on Jul 19, 2009
guitarman002
  • 80 Answers
SOURCE: No test tone from subwoofer during balance testing Yamaha RX-V430
there's no test tone under normal use for the sub. It only shoud test the three front and two rear. ther' are disc you can use to test all the speakers. ( If you are into Pink Folyd, the movie The Wall has what you need to help balance the speakers
Posted on Jan 19, 2010
SOURCE: Yamaha RX-550 receiver. Presently, no sound on
This solution helps! I got this unit from a friend and there was no sound from the left channel, and after playing with the input knob, there was sound.
I sprayed alot of electronic cleaner and it worked like magic.
the unit is now in full working mode.
Posted on Mar 22, 2010
Yamaha remote for RX A830 not working
It is new and within the period of warranty. Contact the manufacturer and either have them run you through the process of repair or send it back for factory adjustment.
Don't void the warranty by messing with it yourself.
Jan 11, 2018 | Yamaha Televison & Video
My Yamaha RX-A830 won't play the sub. I've reset the speakers with the mic multiple times but it's still not working. I confirmed that the sub works on another receiver.
There is a difference between SUB and LFE. In 5.1 mode, the LFE is the ".1" channel. It will output bass only when audio information signal is addressed to this channel. In stereo mode, depending of the receiver setting, it can output normal bass when front speakers cannot handle low frequency. In setup menu, you'll probably have to set your Front speakers as "Small" to make the sub channel taking the relay in low frequencies. There also can be many other reasons for your problem but this might be the solution. Good luck!
Dec 02, 2013 | Yamaha RX-A830 A/V Receiver -
I set up my RX-V365 recently, and the center speaker doesnt seem to work. i use it for listening to music, the sound should come out right?
Sound from a speaker, nah, that's an optional feature (kidding).
If you dig into the manual annd go through the setup using the test tones you can prove/disprove the viability of all the speakers and channels. THAT is required before we try to listen to 'music' (assumed 2-channel) on multiple speakers.
Sound Field programs (page 25) can be applied to just about any source. Experiment, even within a given recording. You'll be amazed how different digital processes can make even familiar recordings new and more interesting. I've discovered instruments and sounds in old recording I never noticed before.
Jun 22, 2011 | Yamaha Rx-v365 A/V Home Theater Receiver
I have an old Yamaha RX-V793. It works perfectly fine. Now I have a new LCD screen, a new DVD player and my new cable tv set top box. All 3 take and use HDMI. I'd like to be able to HEAR BOTH my DVD...
hi,
u can make connections only through digital inputs(optical and coaxial). u can connect the digital outputs of ur dvd and cable set top box to the receiver. no way to connect HDMI. HDMI is a high definition media interface. for using it u have to go for a av receiver that supports HDMI.
ok
Dec 23, 2010 | Yamaha RX-V793
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
Dvd installation
Why do you need to connect the rca cables when you get better sound through hdmi?
Feb 20, 2008 | Yamaha RX-V1800
Open Questions:
280 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
