Hotpoint Aqualtis AQXXD169PM
The machine does not register button presses. I can keep on pressing buttons and eventually get it working, but I have to put teh childlock on otherwise it will see constant button presses mainly from the temperature button. I have taken the PCB out and checked, but cannot see any obvious faults. I've used an air duster on all the button parts, but cannot resolve the problem. I want to replace the PCB, but cant find it as a spare part, I have found the door to an AQXGD169PM for sale, do you know if the PCBs are the same? It is the same button layout.
    Problem Solver:
  • 5 Answers
Could it be that some liquid or cleaning fluid has got into the plastic membrane, if it has one, behind the switches? I had a microwave that did this once.
Posted on Dec 26, 2013
  • ryan morano
    ryan morano Dec 26, 2013
    possible, but it is actual buttons on the PCB not a membrane and they all seem to be pressing ok with no stickiness etc.
gittos73
  • 244 Answers
SOURCE: No power to washing machine but fuse is ok...
could be 2 things 1)try closing the door and banging the machine on the front next to where your door catch goes into the washer if it starts could have a lose wire or be faulty 2)if no1 doesnt work than it will be your mains filter which if blown power doesnt get to your machine if the machine is brand new and has manufacturers warranty then these are covered through the warranty and any tampering will void your warranty though should be covered for no less than a year
Posted on Aug 22, 2007
SOURCE: My washing machine wont work properly!!!!!
may i suggest that you check that the filter is not blocked, i had a very similar problem to this except my machine stopped washing and started making a beeping noise.hope this helps
Posted on Aug 03, 2008
SOURCE: reset childlock model mah2400aww
i just got a maytag epic z washer and dryer the epic washer door locks and when i stopped it the door wont rest and open what do i do to re set it?
Posted on Feb 12, 2009
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Posted on Sep 09, 2009
SOURCE: I have a Hotpoint Aqualtis washing machine. It is not working
Check if the waste pipe isnt blocked.
Posted on Jun 28, 2010
Aqualtis AC1 13DA 6971 Door does not lock
try leaning on the door when pressing start
Dec 26, 2015 | Hotpoint Washing Machines
Tip
End of day reports (Z) for cash registers
SHARP
Most simple machines:
Turn key to Z or Z/P mode.
Press decimal point button
Press TL (your CASH button)
Most mid to high end machines:
Turn key to Z mode.
Type 100
Press X (next to decimal point). In USA, this button is called @/FOR
CASIO
Most machines:
Turn key to Z mode.
Press CASH
SAMSUNG
Most machines:
Turn key to Z mode.
Press 1
Press SUBTOTAL
OMRON
Older machines such as RS3010 and 3460:
Turn key to Z mode.
press 00 (double zero button)
Press X/Z button
If your brand is not listed, or these codes don't work, feel free to post a question in the forum.
Mark
on Jun 30, 2008 | Casio Parts Cash Register PC Desktop
Hotpoint Aqualtis throws water out of soap draw during rinse. Have checked pressure switch & tubing. How do you get to the pressure chamber to check for blockage? Could it be anything else?
I would remove the dispenser drawer by pressing on the release button, then clean out under the drawer. The reason I say this is I have had a few do this and I found a rinse agent clogging unit it cause the water during rinse to dispense forward and leak on the floor. It not difficult to clean out, this can take up to 10 minutes or so to fix with no parts needed.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 31, 2011 | Hotpoint Washing Machines
Hi we have a Hotpoint Aqualtis AQXXD169PM washuing machine that is approx 3 years old. It has worked fin until a day or so ago when taking out the washing it was still soaking wet. After investigation it...
Assuming that the pump is okay and water is draining properly,Could be the speed control module or motor brushes,normally they last around 5 years and wear out simple to fit , you could remove one from the motor to check that is not worn right down to Zilch,if these are okay then you may need an engineer,as this is quite an expensive part to fit,you could phone hotpoint they charge around 100GBP,to repair......Parts are supplied free of charge with a call out hence the £100...hope you get on ok...
Mar 19, 2011 | Washing Machines
Hotpoint washing machine model WF620, keeps reading TEST when you select the programme.
depending on which version you have to
Press the 'Start / Cancel' button until ALL the console LEDs illuminate.
then either
1.Press both 'Start / Cancel' and 'On / Off' buttons together until 'd OFF' appears.
or
2. Press 'On / Off' and 'Start / Cancel' together with the top left option button (Spin) until 'd oFF' appears.
Mar 14, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My idect D1i phone keeps asking me to register
Hi , The phones which keep saying Register mean that they have lost the coding for the Base. To re-code them all you do is
press the menu button,
Press down Button 3 times until Setting comes on the screen,
Press the Button Phone/Ok,
The Display should display HANDSET SETTING,
Press the Button Phone/Ok ,
Then Press the Down button about 4 times until Register Comes on the screen,
Enter Base pin ( 0000 )
The Display will show REGISTER IN PROGRESS,
then immediatly press the Handset Locator Button on the Base and hold it in until you hear a tone.
Thats it , the screen should display Register Done.
Mar 06, 2010 | Lands Phones
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Nov 26, 2006 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD645
If you by accident press the start button and the cancel button at the same time it puts the washer into demo mode.To switch it off press both buttons at the same time and hold until dEND is displayed. Sometimes you have to keep trying but it will work, it did with mine ok.
Sep 09, 2006 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
