Question about Toys
Rc helicopter my remote helicopter has four blades two on top and two on bottom. i got it stuck, and tried to fly out of it. now my the two bottom blades touch the body when it spins it still flys but now it makes a loud sound. how can i raise the two bottom blades back up?
    New Friend:
  • 24 Answers
There might be a small knut beneath the lower set of blades that you can screw up or if its cheap a rubber band like object,
ps dont fly it if the lower blades are touching it will damage the blades (is plastic) and if they are carbon or aluminium they WILL damage the body and/or electronics
Posted on Dec 26, 2013
  • 7 Answers
SOURCE: how do i fly my spin master air hog rc helicopter
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Posted on Feb 15, 2010
micromend
  • 748 Answers
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
Posted on May 13, 2010
  • 4 Answers
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
Posted on Sep 08, 2010
SOURCE: hi i have a Syma
i had one
Posted on Dec 31, 2010
  • 30 Answers
SOURCE: hello i have rc helicopter
depening on the size of the copter if it is a motorized one then you need to check the pitch of the main rotors and check that the collective is working in conjunction with the increase of revs from the motor ie more revs = more lift
the amount of pitch required should be in the setting up instructions
hope this helps
Posted on Aug 11, 2011
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 | Toys
My Smya s109 top blade will come off every time i fly it.
Sounds like you have a defect or something broken. Check your parts up close and see if you can find the defect. Spare parts are available for this unit. Then again the whole units only about 20.00. Try this link for parts . http://www.feala.com/syma_s109g_helicopter_and_spare_parts.htm
Jan 04, 2015 | Syma Brand New S109 AH-64 Gyro Helicopter...
How to fix the lower blades of ModelArt 3.5 channel RC Helicopter
One of the other gears in the blade have probably been broken if the blade has been held or stuck when trying to fly. Might need to replace gear.
May 07, 2014 | Toys
Helicopter will not fly, just goes in circles
try pressing right or left on the remote or try flicking the joystick forward slow
Feb 17, 2014 | RC Helicopter Select Sanhuan SH 6030 C7...
I have Brookstones silver bullet u control helicopter and have a problem. I crashed it, and when I went to fly it again it seems like the bottom blade is hit off the tail of the helicopter. Do I just...
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Dec 27, 2010 | Shuttle 9094 Emax Remote Control...
Why aren't my bottom rotor blades moving?
gear for prop may have come loose. check under shell
Dec 26, 2010 | RC Apache Helicopter 4 Channel Remote...
My rc helicopter can not fly it spin in floor
Hi
May 11, 2010 | RC New 3 Ch Co-Comanche RAH-66 Helicopter
My rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
May 13, 2010 | Radio Shack Indoor Micro Mosquito Rc...
Will not stop spinnig to the left
The heli will do that if you hover less than 1meter from the floor ! or you may need to adjust the swash plate screws Look at them very carefully and draw a diagram if you remove a screw and replace screw into another hole , in case you want to put it back as it was?,Also remove two of those little [8]shaped hooks that tie the blades to the main shaft. Remove one from the top A set of blades and one from the Lower B set of blades You dont need to have all four connected at once.If you click on this link http://www.maplin.co.uk/Media/PDFs/N32FR%20manual.pdf it has the complete operating manual of your apache model in Pdf form (U Will need to download Adobe reader)
Oct 28, 2009 | Electric 4 CH Feral Beast AH-64 APACHE...
Toys Logo
70 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
