Question about Garden
Any tips for adding depth to my inner city garden?
  • 4 Answers
Posted on Oct 16, 2014
    Problem Solver:
  • 15 Answers
Try using a mirror. If you place it stregically by the plants, you can add an illusion of depth.
Posted on Dec 26, 2013
  • david Aug 20, 2014
    Place a silver metal garbage can out.Fill with a big bag of soil..place a sago palm in the middle.
The grass collection tube keeps getting plugged up and will not pass into collection bins.
Tom, Grass chutes get rough on the inner walls of chute over time, try to wipe/scrub inner chute the best you can. After thoroughly clean and dry, try and wax and buff inner chute with car wax the best you can, so chute will be a little more slippery and expel grass better. You may have to do this once or twice a season. Good Luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 16, 2016 | Garden
Water capacity kawe860w
I don't have the number for you, but I can offer a method for measuring it. First, the next time you do laundry, set the water level switch to where you will use it for the dyeing task. With the lid open, but with no clothes inside, turn on the washing machine. Observe and note the level of the water when the machine stops filling. Measure the depth of the water. Add clothes and detergent and wash in the usual manner - you don't need to waste that water.
Next, pour four gallon jugs of water into a clean five-gallon pail, and mark the level in the pail (four gallons in the pail is much easier to handle than a brim-full five gallons). Pour that into the machine, and measure the depth. Put in another four gallons of water, and measure the depth again. If the bottom part of the agitator is covered by the first four gallons, you can can calculate from the increase in depth made by the second four gallons how many more gallons you need to get to the fill depth. (The bottom of the agitator takes up more volume per inch of depth than the center and top,) If the bottom of the agitator is not covered by the first four gallons, but is covered by the second four, then add a third four-gallon pour and measure the depth once more.
Here is an example measurement: water depth on chosen load size setting: 16 inches.
Depth on first four gallons: 2 1/2 inches (some of the water is under the bottom of the inner tub). The agitator bottom taper is almost covered, but not quite.
Depth on second four gallons: 7 inches. The water level is above the bottom section of the agitator, so from this point the water depth will increase by the same amount per gallon added.
Depth on the third four gallons: 11 inches. We can now see that from this point, adding four gallons makes the water level go up four inches, so to reach the 16 inch mark,we need five more gallons. The total will be 4+4+4+5 = 17 gallons.
For what it's worth, there's about 7.48 gallons per cubic foot. If your machine's outer tub holds an additional cubic foot of water, my example numbers may be roughly what you will get.
Apr 24, 2014 | KitchenAid KAWS850L Top Load Washer
Adjust depth on pneumatic stapler
I have noticed that many nailers do not have a way to adjust the depth. Usually there is a thumb screw under the trigger or on the side of the safety foot. If no visual way to adjust, you must get creative. The bumper stops the driver at the bottom of the cylinder. Adding layer of rubber (inner tube or similar) under the bumper will cause the driver extend less and shaving the bumper will cause it to drive deeper. Another method if to add material to tip of safety to space gun away from work (less deep, using various thickness of spacers like used on flooring nailers) or grind the tip of the driver (cant reverse but if driver is too long grind away) . Buy a spare driver and make adjustment to tip for when you need different setting. Good luck
Aug 28, 2012 | Surebonder Stapler. Pneumatic 1/4 in....
How do I adjust depth
You can adjust the depth by adjusting the heights of the wheels and how far the lever drops the mower deck...
Adjusting the wheels higher will allow the deck to go lower...
heatman101
Apr 23, 2011 | Garden
My pony wants to just take off just pulls across the garden no matter where i set the depth handle what do i do so my tiller will just dig the garden
Your garden seems to be especially hard. Set the depth to the minimum and hold it back if it wants to run away with you. Continue back and forth ... maybe side to side ... increasing the depth slightly as you complete each series of passes. Key is holding it back.
Sep 13, 2010 | Troy Garden
Need specs for installation of a concrete cistern in northern alb
call the concrete plant for the specs. check for the freeze depth in your city and bury it atleast a foot deeper then the freeze depth. when i install septic and grease traps we over excavate atleast a foot to a foot and half and bring in pea gravel to make up the distance. the pea gravel tends to not settle as much.
Jul 27, 2009 | Home
Garden Logo
1,600 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
