Question about Jazz Audio Players & Recorders
What is the voltage of the adapter for jazz j-318
Jazz dvx40 power-on/off problem
Yes. Take the batteries out to make it go off. You did not add the SD card yet, did you. The SD card are tricky also if it comes with an adapter you have to insert the SD card adapter into the bottom of the SD card and insert it into the Jazz to get it to work properly. Instructions are available online with Google search. These are so tiny you won't think it will go in there but it clicks in perfectly when you find the right edge. And, check the lock on the SD card to unlock instructions for this are also in a Google search. If all else fails get a replacement. It should work if you do all of these things (even on Ubuntu0.
Feb 06, 2014 | Jazz Dvx40 Video Recorder With Built In...
Won't turn on
Your computer isn't recognizing the camera and you may need to install some software in order for it to do so.
Another thing? Are you trying to charge it? In my experience, Jazz cameras will only charge with an adapter that is usually included with the camera. Hope this helps.
Jan 19, 2012 | Jazz DV-179 Digital Camera
Jazz camera bought from the U.S.. Once we changed the adapter to charge the battery in Europe, including the charger in the network signal and does not want to work
you should be able to charge the battery using a usb cable from your computer. see photo for type of usb cable you need. this cable should have come with the camera.
Hope this helps!
Tom
Mar 02, 2011 | Jazz HDV-188 Camcorder
Can't find my charge adapter for my Jazz HD 188. Will it charge by plugging into the USB port of my PC?
Some phones charge the battery in the camera like a phone, but many do not. This camera has a USB connection, which is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
However, if your charger charged the batteries outside the phone, by removing them from the phone and placing them in the charger, then it is very unlikely that they will charge in the phone, whatever you connect to it. I have a camera just like this, that requires an external charger.
Oct 30, 2010 | Jazz HDV-188 Camcorder
My camcorder want work
see the voltage or charge whit another charge
Sep 09, 2009 | Jazz HDV-188 Camcorder
I have a Jazz HDV178 where does the adaptor plug in
The USB adapter gets plugged in the back. The HDMI cable gt plugged in under the flash (take off the HDMI cover)
Jun 12, 2009 | Jazz DV-179 Digital Camera
Charging on a usb
According to the manual, the HDV188 will not charge via USB, it will only charge using the supplied AC adapter.
Feb 06, 2009 | Jazz DV-179 Digital Camera
Help
One option you have is to get an adapter so you can plug the usb end into the adapter and then plug into the wall and it should charge. I just got this camera like 10 minutes ago so I'm not sure if you can plug it into the computer to charge it. You've had it for atleast 6 days so you probly already have found an answer to this.
Jun 22, 2008 | Jazz DV-179 Digital Camera
Jazz hdv178
You can use any USB type charger that's actually ment to charge MP3 players. One end is the AC adapter and the other is a micro USB connector.
Jun 20, 2008 | Cameras
104 people viewed this question
Top Jazz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Jazz Audio Player and Recorder Expert? Answer questions, earn points and help others
