Question about Brother Office Equipment & Supplies
"To continue installation, please restart your pc"
To continue working where you left off, please restart Audition.
To continue working where you left off, please restart Audition, then I received the "Run Time Error" msge. Restarting did not work, however, re-installing worked perfect.
May 25, 2012 | Adobe Audition 3.0 Full Version for PC
THERE'S GOT TO BE A SOLUTION TO MY LAPTOP PROBLEM,I KEEP GETTING THIS MESSAGE, "THE COMPUTER RESTARTED UNEXPECTEDLY OR AN UNEXPECTED ERROR. WINDOWS INSTALLATION CANNOT PROCEED TO INSTALL WINDOWS,...
The problem is caused by a damaged Windows installation CD.
There are some files that cannot be read from CD, so Windows gets stuck.
It tries to restart to continue with installation, and keeps doing this on an endless loop.
Solution:
Get a goos Windows Installation CD and start from scratch, (format and load the new copy of Windows)
Don't forget to rate this answer if it helps.
Jan 27, 2011 | Everex StepNote VA4300M Notebook PC
I am installing os windows xp sp2 19 minutes left power shut off 3 times , when power on windows start up to mouse arrow pop up, what shall I to continue installation acer laptop?
The computer will continue to reinstall windows. It will say restarting installation, simply continue. If it stops again make sure you are using a good copy of OS CD and not a pirated one. Do a full format before attempting to install one.
Nov 28, 2010 | Computers & Internet
I want to know how to install pc suite in my pc. i want to upload my pictures from my phone to my pc but i dont know how. can u help me?
  1. Browse to Nokia PC Suite web site.
  2. Start the installation by downloading the file.
  3. As you start, the Security Warning window appears. Select Run to begin downloading the installation file. When the download is complete, select Run once again.
  4. Welcome and introduction window opens, select Continue installation to continue.
  5. In order to continue installation, accept the terms and conditions of the license agreement and select Next.
  6. You can select a folder for the installation of Nokia PC Suite. Then, select Continue installation.
  7. Select Continue installation once again to start installing Nokia PC Suite. The installation may take several minutes.
  8. Select Finish to complete the installation.
  9. After the installation is completed, you need to restart your PC for the changes to take effect. You can choose whether to restart your PC right away or later.
Nov 07, 2010 | Computers & Internet
Im trying to install Norton 360 3.0 and a window keeps poping up saying '' an older Norton product has been removed, to continue installing new product restart your computer now.'' I keep restarting but...
Go here choose the prevous verison link you need
follow the instructions on the download page
after uninstalling you should be able to upgrade no problem
Hope this helps
please leave feedback
Nov 27, 2009 | Symantec Norton 360 Full Version for PC...
I cannot get my Evesham PC to boot up in anything other than "safe mode"...
Yours windows installation is corrupt. If u know how to install windows u can rectify the problem with the repair option. If u don't know call a technician.
To repair please do the following:
Go to bios setup and select cd/dvd as the first bootable device.
Put the Windows CD in the drive and save settings and exit.
Installation process will start copying files to hard disk and after sometime computer will restart. Here DON'T PRESS 'R" for repair; but continue. Continue till you get to the Terms and Agreement where u have to press F8. The screen that comes after this will have an option to "Repair". Select this option. Some more files will be copied to the hard disk. When asked for restart remove Windows CD and start computer. Your windows will be repaired with all the data and programmes intact.
Dec 17, 2008 | Evesham Axis PC Desktop
Packard bell restore new Hdu
From parkard bell suppport website Quote
"Step 4 - Re-installing your software
Call the help desk and ask them to guide you through the
ExtHS process.
Please have your Recovery CDs to hand when you call
the Easy Repair line.
Once you have completed the ExtHS process you will
need to re-install Windows and the other software supplied
with your Packard Bell computer. To do this follow the
steps below:
1. Disconnect all peripheral devices (web cam, printer,
scanner, broadband modem etc.).
2. Insert the Packard Bell Master CD 1 / DVD in the top
CD / DVD drive and restart your computer.
3. The CD will load and display the following message:
Please refer to the section headed Packard Bell
Recovery Program in your user’s guide for instructions
on this utility. Press OK if you want to continue
or Cancel to return to DOS.
4. Press the letter O on your keyboard to continue.
5. You will see a menu with options. Please select option 1
“Standard System Restore”
by pressing the 1 key on
your keyboard.
6. A warning message about data loss will be displayed.
Press the letter O to continue.
7. The process will take around 40 minutes. Once this is
done you will need to restart your PC. Remove the CDs
and store them in a safe place.
8. If there was a Software Library DVD supplied with your
PC you can use this to install the extra software that was
supplied with your computer. Insert this into the drive
and follow the onscreen instructions.
9. Finally, you will need to install any additional devices
(web cam, printer, etc.) and software by following the
instructions supplied with them."
Jun 09, 2008 | Packard Bell Computers & Internet
Restarts
hello!
Please fix all cables inside the system, remove and fix back the memory.
sometimes this problem cause by low voltage power supply. if you are sure that the PSU and also cause by software and hardware conflict that when booting the system and tend to load the windows it will detect error and protecting the system by turning it off or restart it automatically.
In this case, if you have newly installed hardware please remove it. if none of those then maybe you should test your memory for errors. if the memory function well; then, try to boot your system in safemode by pressing "F8" on first start. if the system continue booting in safe mode, unistall all the drivers of you computer and then restart. if the system continue starting in normal mode time to reinstall all the drivers of your system.
If this solution is not working then, there is no other option except reinstalling your Operating system i am sure this ultimately resolve the problem.
Hope this help!
best regards, melnavz
Feb 20, 2008 | Systemax AOL Optimized PC (100607) PC...
Installing Updates
just press the off button and then turn back on again the downloaded updates will continue after that
Oct 28, 2007 | Acer Aspire 5500 5570-2609 Laptop
374 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
